This summer I took out the old edelbrock "high flow" pump and put in a aluminum GMB that I got for $20 from Amazon to see if it cooled the same or any worse or better than the expensive eddy pump. No change and used a superformance gasket with no silicone and no leaks or anything....Cools just as good as the edelbrock. 'Net research shows that the milodon pump is repackaged GMB. There's a standard flow and a high flow. The high flow has the anti cavitation plate. Standard ranges from $20-30. High flow ranges from 40-50. Rich Ehrenberg sells something similar on ebay too for 40 + shipping.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
