Re: good aluminum bb waterpump ? [Re: tman] #1999412
01/26/16 11:27 PM
01/26/16 11:27 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Originally Posted By tman
I'm thinking the OP is asking about the WATER PUMP.
if he starts up another thread about the housing,
i wonder if will he get the answer he wants? laugh2
Re: good aluminum bb waterpump ? [Re: pettyblue440] #1999820
01/27/16 03:45 PM
01/27/16 03:45 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Buy the Mopar one
2011 Drag Pak Challenger
Re: good aluminum bb waterpump ? [Re: pettyblue440] #1999849
01/27/16 04:25 PM
01/27/16 04:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I bought the Milodon aluminum pump. It sat in the house for a year or two before I installed it. The pump leaked. It had been so long since I bought it I didn't try to have it warrantied.
- Stu Harmon
Re: good aluminum bb waterpump ? [Re: pettyblue440] #1999904
01/27/16 06:39 PM
01/27/16 06:39 PM
AndyF Offline
AndyF  Offline
Originally Posted By pettyblue440
who makes a good aluminum water pump? I remember reading there were some bad ones going around a while back. thanks ,jon
I've never heard of any bad water pumps. Some work better than others and some are lot more expensive than others. Go to Summit and look at all of the water pumps for BB Mopar engines. I think there are 9 ranging from $35 to $250. If it was me I'd buy two of the $35 pumps and call it good. If the first one didn't work I'd swap in the second one. If the first one worked then I'd drive it until it leaked and then swap in the the other one.
Re: good aluminum bb waterpump ? [Re: pettyblue440] #1999926
01/27/16 07:19 PM
01/27/16 07:19 PM
MN
W
Willie68coronet Offline
W
MN
This summer I took out the old edelbrock "high flow" pump and put in a aluminum GMB that I got for $20 from Amazon to see if it cooled the same or any worse or better than the expensive eddy pump. No change and used a superformance gasket with no silicone and no leaks or anything....Cools just as good as the edelbrock. 'Net research shows that the milodon pump is repackaged GMB. There's a standard flow and a high flow. The high flow has the anti cavitation plate. Standard ranges from $20-30. High flow ranges from 40-50. Rich Ehrenberg sells something similar on ebay too for 40 + shipping.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: good aluminum bb waterpump ? [Re: pettyblue440] #1999933
01/27/16 07:31 PM
01/27/16 07:31 PM
AndyF Offline
AndyF  Offline
I bought the expensive Edelbrock pump a few years ago because I figured the expensive stuff must be the good stuff. It seized up after very few miles. I bought the el cheapo replacement aluminum water pump (probably a repacked GMB) and it worked just fine.
