Re: Solid roller lifters for big block...
[Re: ]
#1996938
01/23/16 12:59 PM
01/23/16 12:59 PM
dartman366
Mt. Vernon, Ohio
Well, I've been running bushed Crower bushed lifters for 3 years. My spring pressures are 450 on the seat, 1200 open. My 55mm roller cam is close to an inch. So far I have had no failures and that's what it takes to make a predator engine run. I haven't run 650 open pressures in 20 years but if I did, the needle bearing Morel or Comps would be fine. I had problems with those when I got into the 750-800 lbs range, but I have friends that run the Manley 221424 springs and standard offset Comps and they get 200 passes without a problem. I really like the bushed lifters as if they do start to wear out, they don't deposit extremely hard little needle bearings somewhere in your engine. JMO I agree!! Just figure most guys here are bracket racers and should stay in the "safe" lane lobe wise but cam makers tend act like we all have an engine like yours and get regular guys off in the weeds with crazy high pressures On the dyno you can really see the diff in lobes and what it takes to control the newest lobes--it is relaxing to run an "old" style lobe that can be controlled with lower pressures--they can still make big beautiful HP in most stock block combos The proof of all this conversation is the trend of everyone having lifter issues and crushing out the needles--the conversation always starts out--"well..my cam grinder said I need 1000 open" then " I got 20 runs and wheel fell off of lifters" always comes back to the "new" cam they started using I miss the days of the old .590 solid in a 440 and a J converter--:) This is good info guy's, I don't intend on using a cam with anywhere near the 450 on the seat or 1200 over the nose, somthing closer to 240 on the seat and mid 600 range in lift, I am presently running Crane ultra pro's in my small block with out failure and have no problem running them again but I am just testing the waters as to what others are using with good results.
[Re: mopar dave]
#1996972
01/23/16 01:44 PM
01/23/16 01:44 PM
dartman366
Mt. Vernon, Ohio
my unbushed lifter bores in my 360 block leak real bad with the crane ultra pros. do you have bushed bores in your block? Yes I do.
[Re: dartman366]
#1997012
01/23/16 02:30 PM
01/23/16 02:30 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I thought Cam FX were the shizz bizz?
Mopar to the bone!!!
[Re: ]
#1997040
01/23/16 03:08 PM
01/23/16 03:08 PM
Jerry Kathe
Well, I've been running bushed Crower bushed lifters for 3 years. My spring pressures are 450 on the seat, 1200 open. My 55mm roller cam is close to an inch. So far I have had no failures and that's what it takes to make a predator engine run. I haven't run 650 open pressures in 20 years but if I did, the needle bearing Morel or Comps would be fine. I had problems with those when I got into the 750-800 lbs range, but I have friends that run the Manley 221424 springs and standard offset Comps and they get 200 passes without a problem. I really like the bushed lifters as if they do start to wear out, they don't deposit extremely hard little needle bearings somewhere in your engine. JMO I agree!! Just figure most guys here are bracket racers and should stay in the "safe" lane lobe wise but cam makers tend act like we all have an engine like yours and get regular guys off in the weeds with crazy high pressures On the dyno you can really see the diff in lobes and what it takes to control the newest lobes--it is relaxing to run an "old" style lobe that can be controlled with lower pressures--they can still make big beautiful HP in most stock block combos The proof of all this conversation is the trend of everyone having lifter issues and crushing out the needles--the conversation always starts out--"well..my cam grinder said I need 1000 open" then " I got 20 runs and wheel fell off of lifters" always comes back to the "new" cam they started using I miss the days of the old .590 solid in a 440 and a J converter--:) Allow me to condense it a little - The best lifters in existence for the most extreme applications do not use bushings. Do you think they would use needle bearings in a fuel motor if they were inferior to bushings?.....think of the cylinder pressure combined with static spring load that is required to open the exhaust valve here....just saying.....
[Re: camastomcat]
#1997041
01/23/16 03:09 PM
01/23/16 03:09 PM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
I thought Cam FX were the shizz bizz? That's debatable. Please expand on this thought.
[Re: dartman366]
#1997067
01/23/16 03:43 PM
01/23/16 03:43 PM
Posts: 31,082 Oregon
AndyF
my unbushed lifter bores in my 360 block leak real bad with the crane ultra pros. do you have bushed bores in your block? Yes I do. Since you have bushed bores then you have more options. I have a new set of Crower lifters which are designed for a bushed block. They can pushrod oil if you want that too. These are new but I can't use them since my block isn't bushed. I'll make you a good price on them if you want.
[Re: Jerry Kathe]
#1997088
01/23/16 04:12 PM
01/23/16 04:12 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Well, I've been running bushed Crower bushed lifters for 3 years. My spring pressures are 450 on the seat, 1200 open. My 55mm roller cam is close to an inch. So far I have had no failures and that's what it takes to make a predator engine run. I haven't run 650 open pressures in 20 years but if I did, the needle bearing Morel or Comps would be fine. I had problems with those when I got into the 750-800 lbs range, but I have friends that run the Manley 221424 springs and standard offset Comps and they get 200 passes without a problem. I really like the bushed lifters as if they do start to wear out, they don't deposit extremely hard little needle bearings somewhere in your engine. JMO I agree!! Just figure most guys here are bracket racers and should stay in the "safe" lane lobe wise but cam makers tend act like we all have an engine like yours and get regular guys off in the weeds with crazy high pressures On the dyno you can really see the diff in lobes and what it takes to control the newest lobes--it is relaxing to run an "old" style lobe that can be controlled with lower pressures--they can still make big beautiful HP in most stock block combos The proof of all this conversation is the trend of everyone having lifter issues and crushing out the needles--the conversation always starts out--"well..my cam grinder said I need 1000 open" then " I got 20 runs and wheel fell off of lifters" always comes back to the "new" cam they started using I miss the days of the old .590 solid in a 440 and a J converter--:) Allow me to condense it a little - The best lifters in existence for the most extreme applications do not use bushings. Do you think they would use needle bearings in a fuel motor if they were inferior to bushings?.....think of the cylinder pressure combined with static spring load that is required to open the exhaust valve here....just saying..... if your only putting 10 passes or less it wouldn't mater, would it? I'm sure needle bearings could be a very slight advsntage. No way they last as long. Doug
[Re: dvw]
#1997106
01/23/16 04:43 PM
01/23/16 04:43 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Fuel engines use a solid bar with no roller tip on the exhaust rocker. The roller will NOT stand up to the exhaust valve pressures on those engines.
[Re: ]
#1997125
01/23/16 05:06 PM
01/23/16 05:06 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
no offsets I think wheel is .750 have to check but feel sure that is what they are I'm really suprised that a "good" lifter company would use the smaller .750 wheels on thier better roller lifters instead of the .820, .840 or larger roller wheels ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) The larger the diameter of the roller wheel the less revoluotions it will make during a run which helps prevent early failures ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) ![work work](/ubbthreads/images/graemlins/custom/work.gif) All the better solid roller lifters I've bought and used, no matter which brands, all have had the larger .820 or bigger wheels in the last 5 to 8 yrs on there Mopar .903 or .904 roller lifters ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: dartman366]
#1997142
01/23/16 05:32 PM
01/23/16 05:32 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Most everything we do here is at a fairly high level and in the past had always used Jesel "keyway" lifters and never had an issue, other than the price. On the advice of Charlie @ Buck Racing Engines, I switched over to Cam FX lifters and have been nothing but pleased. They hold up as well as the Jesels and are a good bit cheaper.
Have also used Morel's in other combos with no issues. While some get good results from the $350 Comps and others in that price range, it all depends on the combination and pressures involved. Like some of the others though, I haven't built a motor with low spring pressures in several years, because that's just not what we do...........But I will say, that I recently built a fairly moderate motor for myself, for a mostly street deal, with a much milder cam profile. I still used a "good" lifter in it, just for the peace of mind. Have had and seen too many failures from the "cheaper" lifters and just won't risk it. We see issues with the bodies starting to "fork" at the bottom, then other problems ensue
[Re: Monte_Smith]
#1997227
01/23/16 08:24 PM
01/23/16 08:24 PM
dartman366
Mt. Vernon, Ohio
I am not looking for a cheaper lifter just looking for good options in case I cannot get what I want at the time I need them, when I bought the Cranes back 6 or so years ago I was under the understanding that the ultra-pro series was a very good lifter at the time and I was looking for pushrod oiling also so thats the ones that I selected, I later found out that the set I aquired was the last known new set in existance, (this was back when crane was having difficulties and wasn't producing alot of stuff anymore)so I almost didn't get them,what would I of setteled for? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) who knows,,,and those lifter's were over $700.00 at that time,,this 400 block WILL get the lifter bores bushed also, for all the reason's I did my small block plus the factory bores are way oversize by .003 to .005 and out of round, it probably looked like a sprinkler in the valley, so what I am doing is researching to find a selection I can work from, for a lifter that I can rely on and don't have to loose any sleep over, $350.00 lifters won't cut it with me and $1000.00 lifters are just not in the budget either,,Great thread guy's lot's of good info as always. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: dartman366]
#1997382
01/23/16 11:46 PM
01/23/16 11:46 PM
Posts: 4,457 Washington
madscientist
Washington
I would never use a lifter with a .750 wheel on any Chrysler cam core. Ever. Even though guys get away with it. As Cab said, the wheel speed is too great, and (I learned this through experience and Wayne Jesel) the wheel/axle/bearing beconme a tuning fork and literally explode.
[Re: 68shifter]
#1998242
01/25/16 10:42 AM
01/25/16 10:42 AM
Jerry Kathe
