Measuring for radiator #1996849
01/23/16 05:42 AM
01/23/16 05:42 AM
W
Wagonman1967 Offline OP
W
I would like to get one of the Champion radiators and want to get it correct the first time. Did my 68 Runner have a 26 or 22 inch. 383 A/T no A/c P/S or P/B. Where do you take the Measurment at? The core opening is at 22 1/2. Should be the 22in unit yes,no maybe?? A pic is worth a thousand words.. Thanks. Pro or con on these units also..
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Measuring for radiator [Re: Wagonman1967] #1997021
01/23/16 02:47 PM
01/23/16 02:47 PM
I believe that would be 22. I had a 2 row Champion in my 318 DD ($189 to my door/eBay) & it cooled fine tho a 318 DD would not tax its cooling capabilities. I had to redrill one mounting hole in the dr side flange. I've heard the cooling tubes ain't as big as some rads which was not an issue for me but might be with you and reportedly some of em arrive & ain't flat and the welds are poor. reportedly they have addressed those issues tho I'm sure a bad one could slip thru & the guy on here who sells em offers a 100% satisfaction guarantee & you cant beat that exc for the down time & likely your nickel on the shipping return. I would ask if it has provisions to use a schroud & in your case get a 3 row & I think you'll be happy. Gotta paint em they do look unsightly! Short version: quality control has been dramatically improved/many people are very happy with em. You might also check what Speedway Motors has to offer (& they do mailorder also)
Re: Measuring for radiator [Re: Wagonman1967] #1997031
01/23/16 02:58 PM
01/23/16 02:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you go to championradiators.com they list the dimensions and have pictures.
Don't be the exception.
Re: Measuring for radiator [Re: Wagonman1967] #1997085
01/23/16 04:08 PM
01/23/16 04:08 PM
W
W
Thanks Will check their site.
2001 Dodge Ram 4wd
