Re: Cam Degree Wheel Pointer? WTB
[Re: cjskotni]
#1995717
01/21/16 06:00 PM
01/21/16 06:00 PM
Posts: 3,924 usa
lewtot184
usa
[Re: Black_Bee]
#1995820
01/21/16 07:52 PM
01/21/16 07:52 PM
Posts: 44,235 Bend,OR USA
Cab_Burge
As far as I know, there is no need for anything fancy... just bolt a piece of strong wire (a piece of coat hanger is what I use) to the engine, and bend it to point to wherever you want it to. Just make sure that it is perpendicular to the degree wheel. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I don't normally agree with many magazine writers but that is the way I do mine, I use a smaller degree wheel and use the top 3/8 timing cover bolts, I have one bent up for both the passenger side and drivers side ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) It doesn't hurt to have a spare and a plan B ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: dogdays]
#1995985
01/21/16 10:46 PM
01/21/16 10:46 PM
Posts: 31,342 Oregon
AndyF
I wonder what AndyF uses. Probably the same, but it wouldn't surprise me a bit to see some beautiful machined billet aluminum pointer.
Wire coat hangers might have been the bane of Joan Crawford's existance, but they have degreed in about a million cams.
R. Well since you asked I use a small pointer which I cut out on the laser. It is the correct length to mount on a long stud which comes off the water pump mount.
[Re: 451Mopar]
#1996280
01/22/16 01:12 PM
01/22/16 01:12 PM
RapidRobert
As said, a stout one/dont bump it/then triple check true TDC then go from there
