Vacuum fitting..where to buy?
#1995519
01/21/16 02:50 PM
01/21/16 02:50 PM
Posts: 2,592 None
71rm23
None
Does anyone know where to get the attached vacuum fitting? This is for a '71 RR with power brakes and A/C. Or do I need a three prong one?
Would I need to put anything on the threads like teflon tape?
Re: Vacuum fitting..where to buy?
[Re: 71rm23]
#1995532
01/21/16 03:11 PM
01/21/16 03:11 PM
Posts: 2,592 None
71rm23
None
[Re: 71rm23]
#1995579
01/21/16 04:07 PM
01/21/16 04:07 PM
Posts: 1,686 New Jersey
Dante
New Jersey
Thanks I carry that fitting, part #4092
Dante's Mopar Parts One of the countries largest Interior Dealer, e-mail for a discounted price quote.
[Re: Dante]
#1995664
01/21/16 06:03 PM
01/21/16 06:03 PM
Posts: 2,592 None
71rm23
None
Thanks I carry that fitting, part #4092 Thanks Dante!
[Re: Ronnman]
#1995963
01/21/16 11:25 PM
01/21/16 11:25 PM
RapidRobert
If you do have to cap any of the small unused nipples on it, Ace hardware has colored vac cap slip on covers for pennies each, they call em "screw protectors" so you'll know what to ask for if you go that route. Each size is a different color for easy ID. I even used one on the unused 1/4 (iirc) return nipple on a sending unit (red iirc) & no leaks in years so whatever they are made of it is stout material & will stand up to our (automotive) needs
[Re: RapidRobert]
#1995981
01/21/16 11:43 PM
01/21/16 11:43 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
If you do have to cap any of the small unused nipples on it, Ace hardware has colored vac cap slip on covers for pennies each, they call em "screw protectors" so you'll know what to ask for if you go that route. Each size is a different color for easy ID. I even used one on the unused 1/4 (iirc) return nipple on a sending unit (red iirc) & no leaks in years so whatever they are made of it is stout material & will stand up to our (automotive) needs Personally I do not like using the caps. I had one blow off once, creating a huge vacuum leak a hundred miles from home.. Until I diagnosed it I thought I was going to need counseling... Better, if possible, to get the correct fitting with NO extra nipples....
[Re: 71rm23]
#1996009
01/22/16 12:09 AM
01/22/16 12:09 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Back in my turbo days I had a tendency to pop vacuum lines off nipples like that. So I used a zip tie as a sort of hose clamp to hold them on, never had a failure after that.
