Re: 98 cummins no start no wts light
[Re: 3csalvage]
#1994502
01/19/16 11:49 PM
01/19/16 11:49 PM
Posts: 4,086 The Wet Coast, Canada
megajoltman
Is it a 12V or 24V cummins engine, any codes showing?
What shape are the batteries in?
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: 3csalvage]
#1995088
01/20/16 06:51 PM
01/20/16 06:51 PM
megajoltman
Did you use a code scanner or just turn the key? I thought if the WTS light is NOT coming on is a sign of a internal memory error in the ECM and is having troubles getting booted up. Unless the bulb is burnt out. Are you sure the new ECM is good Is it getting fuel to the filter? Confirm pressure with a mechanical gauge at the banjo bolt and bleed the pressure off through the top bolts on the filter canister to try to get it started. It very well could be the lift pump. The VP44, injector pump, will run once started but it usually doesn't pull enough to get fuel to itself to start. But it will pull fuel once started.
Procharged 350Z
[Re: 3csalvage]
#1995217
01/20/16 11:34 PM
01/20/16 11:34 PM
megajoltman
Well I will say I had lots of fun with wiring issues in my 98 Ram.
But a bad ignition switch won't suprise me.
Procharged 350Z
[Re: 3csalvage]
#1995437
01/21/16 11:28 AM
01/21/16 11:28 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Are you getting a crank signal? you got no fuel if all else is there.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: 3csalvage]
#1995443
01/21/16 11:36 AM
01/21/16 11:36 AM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
some people on the internet are talking about the connector corroding between computers on the firewall. Worth a try to look at it. I know the ECM was my problem when I had that issue.
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
