Re: Another 440 cast vs forged crank debate
[Re: Joey Johnson]
#1994417
01/19/16 10:37 PM
01/19/16 10:37 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I think that a forged crank is in order at that hp level. Why didn't you just buy a full rotating kit from 440 source to start with? A stroker kit wouldn't have cost you any more than a standard 440 kit.
[image][/image]
[Re: Joey Johnson]
#1994460
01/19/16 11:11 PM
01/19/16 11:11 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Yes we all would prefer the steel crank over the cast but how many have you seen let go ?
My first race engine was, still is, a cast crank stock LY rod engine. It's been to hell running 11.00's for years and then high 9's on the bottle over a 150 times. it has a sleeve, 7 TRW pistons and 1 Manley that was shaped with a grinder to match the others, ran a best of 9.69 @ 135. The engine is still going hard in my sons Aussie A body N/A running 11.2.
I would say that a cast crank will be fine up to 600hp.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: GY3]
#1994469
01/19/16 11:16 PM
01/19/16 11:16 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
I've never had a problem with a cast crank. It was the stock, cast pistons that were my undoing! This made me laugh............a lot..........
Curator at Adams County Speed Shop
[Re: 340man4ever]
#1994576
01/20/16 12:53 AM
01/20/16 12:53 AM
Posts: 4,705 Wichita
GY3
Wichita
I've never had a problem with a cast crank. It was the stock, cast pistons that were my undoing! This made me laugh............a lot.......... The people that were following me when it went "boom" on US 54 and had to drive through the cloud of antifreeze probably weren't laughing... ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif)
[Re: ozymaxwedge]
#1994675
01/20/16 02:58 AM
01/20/16 02:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You know if you could get that thing to hook up, it would accelerate a lot faster... Crazy Aussies! (I wanna be a tire salesman in Austrailia!)
[Re: Joey Johnson]
#1994892
01/20/16 02:27 PM
01/20/16 02:27 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
$250 for a stock forged crank that still needs machining??? Holy crap that's high! You ought to be able to find one cheaper than that!
Realistically, I think a cast may be fine for what you want to do, but I'd rather see a forged crank in a motor making that much power. You've already spent good money on a girdle, studs, etc. Get a forged crank and don't worry about it.
[Re: cudaman1969]
#1995073
01/20/16 06:19 PM
01/20/16 06:19 PM
Thumperdart
State of confusion
Jason Pettis found my 413 forged crank 13 years ago ready to drop in my 400 block for about $250 iirc w/chevy rod sizing.........
[Re: cudaman1969]
#1996633
01/22/16 10:22 PM
01/22/16 10:22 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Should be a million of the steel 440 cranks laying around with everyone using strokers now, and cheap too. Like the guy above said, maybe $250 for a done crank. As said in the next post, RB steel cranks hold a premium to go into a B-motor budget stroker. At least $100 for a core that needs turned. $200 at a swapmeet.
[Re: Jerry Kathe]
#1996926
01/23/16 12:39 PM
01/23/16 12:39 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Not splitting hairs, but they are both steel....its not cast iron v/s forged steel. One starts out as a forged billet the other is a poured casting.
Consider this, if you are a budget build (say <500hp) or a just for fun test and tuner, it probably doesn't matter much. If you are hitting it fairly hard, or drive the stripe with the throttle pedal, you should probably stay away from cast. No they are not both steel one is iron and the other is steel its sort of like saying brass and bronze are the same
[Re: The Shadow]
#1997035
01/23/16 03:02 PM
01/23/16 03:02 PM
Jerry Kathe
Consider this, if you are a budget build (say <500hp) or a just for fun test and tuner, it probably doesn't matter much. If you are hitting it fairly hard, or drive the stripe with the throttle pedal, you should probably stay away from cast. No they are not both steel one is iron and the other is steel its sort of like saying brass and bronze are the same I dont remember the ASTM number right off , but here is a link you can refer to until I find or remember it....they ARE cast steel. Not totally relevant, but as in your comment - its like calling brass and bronze as the same. Bottom line, go forged. http://www.hotrod.com/how-to/engine/1405-how-to-tell-forged-crank-from-cast-spotters-guide/
