360 Magnum cam #1994348
01/19/16 09:10 PM
01/19/16 09:10 PM
Harlan, Ky
O
Orange_Duster Offline OP
O
Harlan, Ky
Sorry,I know this has been asked a million times. What cam would you recommend for a 1999 360 magnum going in 1974 Duster with headers, 4 barrel carb, factory high stall converter, 3.21 gears. Would you recommend a split pattern or single pattern also?
Re: 360 Magnum cam [Re: Orange_Duster] #1994398
01/19/16 10:16 PM
01/19/16 10:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Same specs as the stock 340 cam in 1968-71 maybe a little more duration if you don't need vacuum. It's a good all around cam. Get to low on the vacuum and you'll have to work over the carb. A no headache cam.
Re: 360 Magnum cam [Re: Orange_Duster] #1994404
01/19/16 10:22 PM
01/19/16 10:22 PM
scratchnfotraction Offline
Hughes 340/360 flat tappet whiplash cam
or
Hughes Magnum 360 whiplash roller cam
Re: 360 Magnum cam [Re: scratchnfotraction] #1994438
01/19/16 10:51 PM
01/19/16 10:51 PM
dogdays Offline
dogdays  Offline
Single pattern for me, the Mag exhaust port doesn't need a split pattern cam.
I'd pick a Hughes 218 lobe for both intake and exhaust, ground on a 110 LSA. This has 0.539 calculated lift with the Mag 1.6 rockers.
If you're going Mag, then go hydraulic roller as it's easy to get there when starting with a Mag engine.
I think this cam with your setup would be killer.
R.
Re: 360 Magnum cam [Re: Orange_Duster] #1994733
01/20/16 08:58 AM
01/20/16 08:58 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Here is what I put in mine from Hughes
.544 lift with 1.6 rockers
218/228 duration
110 lobe separation
Very nice street cam with about a 2400 stall. The car turns 12.95 and weighs 4200 lbs. 3.55 gears btw.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 360 Magnum cam [Re: Orange_Duster] #1995120
01/20/16 08:04 PM
01/20/16 08:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What intake?
What carb?
How do you want it to behave idle and HP wise? OD or 3 spd auto?
I like single pattern with the magnum heads unless you want to roughen up the idle for no good reason.
Lift and duration gonna depend on a lot of things not mentioned yet.
Re: 360 Magnum cam [Re: HotRodDave] #1995239
01/21/16 12:14 AM
01/21/16 12:14 AM
Harlan, Ky
O
O
Harlan, Ky
I will probably redrill the heads and use a 1971 340 intake that I already have. I have both 650 and 800 spread bore holleys to try, plus a big bore thermo quad also. Trans is 727 with 340 torque converter, I assume stall is around 2400. I would like good low end torque, a slight lope would be ok but not necessary. Fun street car, no track time.
Re: 360 Magnum cam [Re: Orange_Duster] #1995619
01/21/16 05:07 PM
01/21/16 05:07 PM
dogdays Offline
dogdays  Offline
I stick by my choice in your application. Or have Bullet or Delta regrind your stock cam with as much lobe as they can get on it. But I'd stick single pattern.
R.
Re: 360 Magnum cam [Re: dogdays] #1997202
01/23/16 07:22 PM
01/23/16 07:22 PM
Harlan, Ky
O
O
Harlan, Ky
Would 218 degrees at .050 lift be too much for a 2400 stall torque converter and 3.21 rear gears? This will be a regrind from Delta or Oregon cams. Tight budget.
Re: 360 Magnum cam [Re: Orange_Duster] #1997927
01/24/16 09:14 PM
01/24/16 09:14 PM
dogdays Offline
dogdays  Offline
You are talking hydraulic roller, right?
IMHO it'll work just fine.
I believe the stock 5.9 hydraulic roller has 114 or 115 LSA and increasing the duration that much will limit the amount the LSA can be narrowed. That will work in your favor, reducing overlap which will tame the idle and off-idle roughness, allowing a lower stall speed converter to work just fine. It will sacrifice a little midrange torque over my choice of the narrower LSA but probably work better in daily driving.
R.
Re: 360 Magnum cam [Re: dogdays] #1997973
01/24/16 10:10 PM
01/24/16 10:10 PM
Harlan, Ky
O
O
Harlan, Ky
Yes, it will be hydraulic roller.
Re: 360 Magnum cam [Re: Orange_Duster] #1998279
01/25/16 11:52 AM
01/25/16 11:52 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Should be fine. I'm running a 222/228, 107 lsa installed at 104 (whiplash cam). Lots of torque, good drivability, chops at idle, but only has 9" of vacuum.
My vacuum booster hasn't complained and I have plenty of power assist available.
Made 285 rwhp through a manual trans with stock heads. Pushed my 4000 lb truck to traction limited 14.5s at 99 mph.
**Photobucket sucks**
Re: 360 Magnum cam [Re: Orange_Duster] #1998509
01/25/16 05:03 PM
01/25/16 05:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yes, single pattern and 110 LSA almost the exact cam I use in most of my street builds, had one in a 1/2 ton 4x4 with 3.21s and it was ok with the stock converter, a little more stall, little shorter tire and a whole lot less weight should be awesome. I have delta re-grind mine
Re: 360 Magnum cam [Re: HotRodDave] #1998646
01/25/16 09:23 PM
01/25/16 09:23 PM
Harlan, Ky
O
O
Harlan, Ky
HotRodDave, What are the specs on the cam you use? And how much does Delta charge to regrind a roller cam for you?
Re: 360 Magnum cam [Re: Orange_Duster] #2005612
02/04/16 07:33 PM
02/04/16 07:33 PM
Harlan, Ky
O
O
Harlan, Ky
Any other opinions on cam choice? Is Hughes the only source for magnum valve springs?
Re: 360 Magnum cam [Re: dfsmopars] #2005802
02/04/16 11:58 PM
02/04/16 11:58 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
218/228 duration
110 lobe separation
Is there something wrong with this cam? It is in a car with success. It is not speculative.
Re: 360 Magnum cam [Re: Orange_Duster] #2006685
02/06/16 01:23 PM
02/06/16 01:23 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Years ago then Chrysler CEO Tom LaSorta said that he had asked the engineering team to investigate what fuel economy improvement would be had if the then non-variable camshaft profiles were optimized for economy rather than peak horsepower.
The answer came back six percent according to LaSorta.
I wonder what the max torque in the 1400 to 2400 rpm range would be on a max economy camshaft?
What does Delta or Bullet charge to regrind a Magnum camshaft?
