Re: ROLL CENTER [Re: 67autocross] #1993084
01/18/16 01:24 AM
01/18/16 01:24 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Originally Posted By 67autocross
Originally Posted By autoxcuda
Originally Posted By astjp2
1/8 of movement/turning of the spindle is a lot at the tie rod end, probably 3/8" of movement of the tire back and forth...that is more than I would like to get in my b-body
1/8" of movement is a lot at 3 inches of compression?
Think about what is going on a 3" of compression....low speed high G corner... The spindle will be at a high turning angle and straight line bump steer doesn't apply much.
The two measuring points on my commonly used bump steer gauge are 16.5" apart. A typical tire is 26".
I showed my results shown below with a guy that crew chiefs K&N Pro Series championship cars and full time designs and builds his own multi track championship car. 1/8" of bump with the same style gauge I used at 3" is still good and he said don't mess with it. He did say 1/16" would be very good. Of course we're talking cars set up for handling. Not Drag cars.
Getting .001" at jounce AND rebound at 3" is nearly impossible. That's not reality if you've ever did this or did it regularly.
How much wheel travel do you have with your set up?
I don't remember exactly. But it's at least 3" up and down. I ran the gauge with my upper control arm bumper (jounce) and the removed bumper setup I run all the time. Neither hit the limits.
Re: ROLL CENTER [Re: BergmanAutoCraft] #1993269
01/18/16 01:41 PM
01/18/16 01:41 PM
Long Island, NY USA
BergmanAutoCraft Offline OP
Long Island, NY USA
Shock is only 5" in an A body, so it can't be any more than 2.5" in either direction.
Re: ROLL CENTER [Re: BergmanAutoCraft] #1993313
01/18/16 02:32 PM
01/18/16 02:32 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Shock travel and wheel travel are not always the same, shock is at an angle and mounted inboard of balljoint obviously. I know you all know this.
Mopar to the bone!!!
Re: ROLL CENTER [Re: BergmanAutoCraft] #1994544
01/20/16 12:28 AM
01/20/16 12:28 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
..does an Abody have a 1:1 motion ratio?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: ROLL CENTER [Re: BergmanAutoCraft] #1994788
01/20/16 11:36 AM
01/20/16 11:36 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
All longitudal torsion bar mopars have a 1:1 motion ratio for the t-bars. Sway bars and shocks all have different motion ratios across the product lines and are not consistent even among body styles due to changes in sway bar mounting positions and lever arms lengths.
Re: ROLL CENTER [Re: BergmanAutoCraft] #1994949
01/20/16 03:55 PM
01/20/16 03:55 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The last few inches of compression are probably 1:1 ish but on rebound you get over it on my Dart. My guess is with no bump stops and a 5" shock, travel at the tire is more like 6".
Re: ROLL CENTER [Re: autoxcuda] #2177944
10/18/16 05:59 PM
10/18/16 05:59 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I was getting 1/4" toe change per inch of travel on my road course car. Couldn't touch the brakes on corners or it would pull into the turn hard. Installed a bolt and heim joint style tie rod end and got it down to less than .010" toe change per inch of travel, and that problem went away. I don't want to use a heim joint on a street car, though. How do you adjust bump steer on your car?
Re: ROLL CENTER [Re: BergmanAutoCraft] #2177947
10/18/16 06:04 PM
10/18/16 06:04 PM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
I raised the roll center on my road course Fox Mustang by installing a 1/2" longer lower ball joint. QA1 makes longer ball joints that fit some of our cars. Anyone know about using them on our cars and what it would do to camber change and so forth?
Re: ROLL CENTER [Re: 375inStroke] #2178010
10/18/16 07:12 PM
10/18/16 07:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And that would equal 0.03" of toe change per 3" of travel.
I have 0.082" per 3" in compression.
I have the Hotchkis hiems tie rod kit. The measurements I got where with no adjustments (lucked out). The hiems are worn now though.
Re: ROLL CENTER [Re: autoxcuda] #2178174
10/18/16 10:50 PM
10/18/16 10:50 PM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
And that would equal 0.3" of toe change per 3" of travel. I have 0.082" per 3" in compression.
.010", not .100", so .030" for 3" of travel. It started out .250" to .300" per inch of travel, so we're talking over an inch of toe change over full suspension travel. The instructions for the kit said rule of thumb is to keep it less than .020" per inch of travel.
Re: ROLL CENTER [Re: BergmanAutoCraft] #2178203
10/18/16 11:18 PM
10/18/16 11:18 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yea I caught that error. Changed that 10 mins before or while you where replying.
Re: ROLL CENTER [Re: BergmanAutoCraft] #2182888
10/26/16 11:21 AM
10/26/16 11:21 AM
Indiana
dusterpt440 Offline
dusterpt440  Offline
Indiana
well before we can compare, we need the factory specs on a factory car. Does anyone have any of those for an A body? If so, post them up, I should have my new Gerst set up within the next week or so, I can get measurements then to compare if you all wish.
Re: ROLL CENTER [Re: BergmanAutoCraft] #2182984
10/26/16 02:09 PM
10/26/16 02:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Numbers from factory car will vary.
A decent caster change/difference will change a bump steer reading because the steering arm tilts up or down.
But you can get a ball park.
To get it real low you have to make adjustment (shims) like 375 stroke did. Or get lucky.
Re: ROLL CENTER [Re: BergmanAutoCraft] #2185168
10/29/16 10:03 AM
10/29/16 10:03 AM
Indiana
dusterpt440 Offline
dusterpt440  Offline
Indiana
I get that. but if we had a few sets of numbers from "factory" cars, we could generate a decent baseline. Otherwise, it'll be impossible to answer whether or not the original question, which was does the aftermarket kits affect the roll center. My guess is that they do. Question is by how much, granted that'll be car specific but with a rough baseline, the law of averages comes in.
Re: ROLL CENTER [Re: dusterpt440] #2185174
10/29/16 10:18 AM
10/29/16 10:18 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since there seems to be a wide range of understanding of the terms discussed here, to make sure everyone is on same page, roll center is the geometric location on a chassis determined by the suspension linkages as they move thru their respective arcs, and the height of that derived roll center in regards to the measured height of the COG, determines how long the theoretical vertical lever arm is between those two points. That distance is important, as it determines how much the chassis "rolls" when cornering, longer=more. The front and rear usually have different values, intentionally. How did I do? grin
Re: ROLL CENTER [Re: jcc] #2185179
10/29/16 10:32 AM
10/29/16 10:32 AM
Indiana
dusterpt440 Offline
dusterpt440  Offline
Indiana
sounds good to me
