Re: Correct 71 Road Runner horn
[Re: T2R9]
#1992260
01/16/16 10:58 PM
01/16/16 10:58 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
i always thought it went long bracket black was 68 long bracket purple 69-71 short bracket purple 72-up maybe someone can confirm or shoot holes thru what i think
[Re: T2R9]
#1992462
01/17/16 11:32 AM
01/17/16 11:32 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
on my 72 the horn is mounted forward of the radiator support inside of the fender.
your pic looks like a 72 horn. they have threads tapped into the bracket for the bolt thru the fender fender.
perception is 90% of reality
[Re: T2R9]
#1992672
01/17/16 03:56 PM
01/17/16 03:56 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
In my experience, 71 should be the long bracket
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: Butterscotch71]
#1992724
01/17/16 04:41 PM
01/17/16 04:41 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
In my experience, 71 should be the long bracket OK, Thanks, is mine mounted correctly?
[Re: T2R9]
#1993886
01/19/16 03:00 AM
01/19/16 03:00 AM
Posts: 765 Shoreline, Washington
72roadrunnergtx
In my experience, 71 should be the long bracket OK, Thanks, is mine mounted correctly? Would appear your horn is mounted backwards on the bracket, should be facing forward (as Eric’s picture shows). The rivets having been replaced by screws and nuts indicate someone has had it apart.
[Re: T2R9]
#1994000
01/19/16 12:30 PM
01/19/16 12:30 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
FPM shows the same horn for both 70 and 71. All the reproduction companies show different horns for 70 and 71 which doesn't surprise me. They usually don't know what their product fits.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 72roadrunnergtx]
#1994037
01/19/16 01:18 PM
01/19/16 01:18 PM
Posts: 2,592 None
71rm23
None
In my experience, 71 should be the long bracket OK, Thanks, is mine mounted correctly? Would appear your horn is mounted backwards on the bracket, should be facing forward (as Eric’s picture shows). The rivets having been replaced by screws and nuts indicate someone has had it apart. Mine has the long bracket as well and I agree with 72roadrunnergtx that someone had this thing apart. If my memory is correct, a short bracket wont fit both the bolt hole and the tab (where it attaches to inner fender) at the same time.
[Re: 71rm23]
#1994050
01/19/16 01:49 PM
01/19/16 01:49 PM
T2R9
Conway, SC
In my experience, 71 should be the long bracket OK, Thanks, is mine mounted correctly? Would appear your horn is mounted backwards on the bracket, should be facing forward (as Eric’s picture shows). The rivets having been replaced by screws and nuts indicate someone has had it apart. Mine has the long bracket as well and I agree with 72roadrunnergtx that someone had this thing apart. If my memory is correct, a short bracket wont fit both the bolt hole and the tab (where it attaches to inner fender) at the same time. I understand it has been apart and one of the main reasons I asked the question. I bought the short bracket one due to most of the ones I see advertised its listed for 71 and up but obviously is not as moparmarks said. Lots of good info I will look for a nice used original at Carlisle this year.
[Re: T2R9]
#2031191
03/14/16 09:41 PM
03/14/16 09:41 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
What is the decal orientation on a 71 horn?
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#2032702
03/16/16 10:23 PM
03/16/16 10:23 PM
Butterscotch71
Lost Title
Lost Title
What is the decal orientation on a 71 horn? Upside down when mounted on the car. I'll try to get a photo later.
