Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1992308
01/16/16 11:54 PM
01/16/16 11:54 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
There is plenty of meat on them old bones.Pullies get smaller,ET's go down,MPH goes up.I will be adding some weight soon with parachute,engine limiters & "J" bars.Easy diet is the aluminum master with the plasic tank,Aluminum rad and bumper brackets. Been 145mph so this season I will need the chute to keep tech hushed. I have had this car well over 25 years. Has always been a street car 1st.Still on leafs & torsion
[Re: 590 Challenger]
#1992894
01/17/16 07:59 PM
01/17/16 07:59 PM
fullmetaljacket
You're good to go.
[Re: FastmOp]
#1993675
01/18/16 10:32 PM
01/18/16 10:32 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
Aluminum should be doable once or twice in a mold like this. How do you make that happen? I would build it a little different if I knew I was going to try and stamp a part in it. What would be different?
'71 Duster '72 Challenger '17 Ram 1500
#1994457
01/19/16 11:05 PM
01/19/16 11:05 PM
Thumperdart
State of confusion
What about trans bolts............
#1994557
01/20/16 12:37 AM
01/20/16 12:37 AM
Posts: 9,858 MI, usa
dvw
MI, usa
As far as trans fasteners and such, I have been running for some time now aluminum trans pan bolts and Titanium trans to engine bolts. Also have been running speedometer cable housing to trans main body aluminum bolts and a mixture of aluminum/Titanium trans cross member to chassis bolts and trans mount bolts.
I'm about to build an extra trans to have for a spare and will use a limited amount of titanium bolts on the inside. Maybe the tail shaft housing to main housing mounting bolts will be titanium. If your not running full auto cut the park pawl gear teeth down to 1/4" thick. Then trim the main section just after the 1st governor seal ring groove. Eliminate the governor assy. Cut a new snap ring groove in the shaft and your done. You can get 1 lb out of the sun shell also. Doug
