Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992708
01/17/16 04:19 PM
01/17/16 04:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I made my own. I prefer to have more then 3 bolts holding it to the damper.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992722
01/17/16 04:40 PM
01/17/16 04:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
All depends on where the other components fall I suppose. For us flush works best. But when I called they were fairly clueless what to do other than ad a spacer. Not sure how thicker would help unless the hole was opened up as well??? The B1 on the Cuda was the same way
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992726
01/17/16 04:43 PM
01/17/16 04:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW when the Cuda had a Hemi it used an Aerspoce on, so does the dragster. IMO it is a big pile of crap. It is simply to long and don't care for the allen bolt in the end as the only way to turn motor by hand
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1993968
01/19/16 11:46 AM
01/19/16 11:46 AM
an8sec70cuda Offline
I use the DMI low mount alternator bracket setup and a junk Aerospace vacuum pump. When, not if, it fails again, I'll replace it w/ a GZ pump.
I use a drive mandrel setup from CV products. It is the nicest setup I've used. Each pulley and spacer is pinned so they lock together and just use a through bolt to hold the "stack together".
I like it a LOT better than the Aerospace, Moroso, and Enderle drive setups.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What is everyone running for front drive set ups on a BBM? [Re: an8sec70cuda] #1994290
01/19/16 07:21 PM
01/19/16 07:21 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks guys. Still looking at options & this all helps out alot for any of the custom machining i will need to do.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1994313
01/19/16 08:09 PM
01/19/16 08:09 PM
AndyF Offline
AndyF  Offline
You might not need any custom machining if you bite the bullet up front and go with a Chevy bolt pattern damper from ATI.
Re: What is everyone running for front drive set ups on a BBM? [Re: AndyF] #1994320
01/19/16 08:18 PM
01/19/16 08:18 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I used a Weaver Brothers 1.00" Drive mandrel and made a bolt out of 4130 All thread. Screwed a nut on it and welded it.
Re: What is everyone running for front drive set ups on a BBM? [Re: Biginchmopar] #1994327
01/19/16 08:27 PM
01/19/16 08:27 PM
Carson City, Nevada
Carson City, Nevada
Pic #2
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1994382
01/19/16 10:00 PM
01/19/16 10:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use the stock bolt behind the mandrel like Al
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1994674
01/20/16 02:57 AM
01/20/16 02:57 AM
AndyF Offline
AndyF  Offline
Here is a picture of a custom Mopar spline drive mandrel that I built a few years back. This was before I got smart and started using the BB Chevy pattern.
Re: What is everyone running for front drive set ups on a BBM? [Re: AndyF] #1994913
01/20/16 03:03 PM
01/20/16 03:03 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks. Yes, this is the same boat I am in since my ATI damper has the factory 6 bolt pattern.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1994918
01/20/16 03:12 PM
01/20/16 03:12 PM
FWIW...mine is still the normal Mopar pattern. I have a crank trigger also.
CHIP
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1994976
01/20/16 04:28 PM
01/20/16 04:28 PM
AndyF Offline
AndyF  Offline
I made the custom drive by ordering the spline blank from Peterson and then drilling the bolt pattern and counterboring the backside for bolt clearance. It isn't a big job for a decent machine shop. Peterson might even have a Mopar spline these days. I made mine 6 years ago so maybe they've added one since then.
Re: What is everyone running for front drive set ups on a BBM? [Re: an8sec70cuda] #1995005
01/20/16 05:03 PM
01/20/16 05:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here. but all I am going to drive is an alternator and vac pump, have a good machine shop close by so it shouldn't be a issue to fix somthing up.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1995013
01/20/16 05:08 PM
01/20/16 05:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Buy a new balancer, lots more options for sure.
Re: What is everyone running for front drive set ups on a BBM? [Re: dartman366] #1995027
01/20/16 05:19 PM
01/20/16 05:19 PM
I've had no need to machine anything up. shruggy
CHIP
Re: What is everyone running for front drive set ups on a BBM? [Re: an8sec70cuda] #1995056
01/20/16 05:49 PM
01/20/16 05:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I should of added "if needed" at the end. LOL
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1995531
01/21/16 03:10 PM
01/21/16 03:10 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Ron's, Enderly, Kinsler, Hilborn all make mandrels that work.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
