Re: What is everyone running for front drive set ups on a BBM?
[Re: 6PKRTSE]
#1992722
01/17/16 04:40 PM
01/17/16 04:40 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
All depends on where the other components fall I suppose. For us flush works best. But when I called they were fairly clueless what to do other than ad a spacer. Not sure how thicker would help unless the hole was opened up as well??? The B1 on the Cuda was the same way
[Re: 6PKRTSE]
#1992726
01/17/16 04:43 PM
01/17/16 04:43 PM
Al_Alguire
Las Vegas
FWIW when the Cuda had a Hemi it used an Aerspoce on, so does the dragster. IMO it is a big pile of crap. It is simply to long and don't care for the allen bolt in the end as the only way to turn motor by hand
[Re: 6PKRTSE]
#1993968
01/19/16 11:46 AM
01/19/16 11:46 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I use the DMI low mount alternator bracket setup and a junk Aerospace vacuum pump. When, not if, it fails again, I'll replace it w/ a GZ pump.
I use a drive mandrel setup from CV products. It is the nicest setup I've used. Each pulley and spacer is pinned so they lock together and just use a through bolt to hold the "stack together". I like it a LOT better than the Aerospace, Moroso, and Enderle drive setups.
[Re: an8sec70cuda]
#1994290
01/19/16 07:21 PM
01/19/16 07:21 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Thanks guys. Still looking at options & this all helps out alot for any of the custom machining i will need to do.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#1994320
01/19/16 08:18 PM
01/19/16 08:18 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I used a Weaver Brothers 1.00" Drive mandrel and made a bolt out of 4130 All thread. Screwed a nut on it and welded it.
[Re: AndyF]
#1994913
01/20/16 03:03 PM
01/20/16 03:03 PM
6PKRTSE
Motor City
Here is a picture of a custom Mopar spline drive mandrel that I built a few years back. This was before I got smart and started using the BB Chevy pattern. Thanks. Yes, this is the same boat I am in since my ATI damper has the factory 6 bolt pattern.
[Re: 6PKRTSE]
#1994918
01/20/16 03:12 PM
01/20/16 03:12 PM
an8sec70cuda
FWIW...mine is still the normal Mopar pattern. I have a crank trigger also.
[Re: an8sec70cuda]
#1995005
01/20/16 05:03 PM
01/20/16 05:03 PM
dartman366
Mt. Vernon, Ohio
FWIW...mine is still the normal Mopar pattern. I have a crank trigger also. same here. but all I am going to drive is an alternator and vac pump, have a good machine shop close by so it shouldn't be a issue to fix somthing up.
[Re: 6PKRTSE]
#1995013
01/20/16 05:08 PM
01/20/16 05:08 PM
Al_Alguire
Las Vegas
Buy a new balancer, lots more options for sure.
[Re: dartman366]
#1995027
01/20/16 05:19 PM
01/20/16 05:19 PM
an8sec70cuda
FWIW...mine is still the normal Mopar pattern. I have a crank trigger also. same here. but all I am going to drive is an alternator and vac pump, have a good machine shop close by so it shouldn't be a issue to fix somthing up. I've had no need to machine anything up.
[Re: an8sec70cuda]
#1995056
01/20/16 05:49 PM
01/20/16 05:49 PM
dartman366
Mt. Vernon, Ohio
FWIW...mine is still the normal Mopar pattern. I have a crank trigger also. same here. but all I am going to drive is an alternator and vac pump, have a good machine shop close by so it shouldn't be a issue to fix somthing up. I've had no need to machine anything up. I should of added "if needed" at the end. LOL
[Re: 6PKRTSE]
#1995531
01/21/16 03:10 PM
01/21/16 03:10 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Ron's, Enderly, Kinsler, Hilborn all make mandrels that work.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
