Page 2 of 4 1 2 3 4
Re: 70 GTX-5.7 Hemi build-7-14-09 [Re: Darius] #199185
07/14/09 09:31 PM
07/14/09 09:31 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is a frame rail mod I had to make to clear the stock exhaust manifold flange. TTI does NOT make a header for the 5.7 using the w5a580 as the pipes won't clear the starter....according to the design engineer at TTI!
Driving modern convenience in classic beauty
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199186
08/04/09 08:17 PM
08/04/09 08:17 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here are some pics of the 5.7 with the w5a580 installed with the new transmission mount we fabbed up
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199187
08/04/09 08:18 PM
08/04/09 08:18 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
#2
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199188
08/04/09 08:19 PM
08/04/09 08:19 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
3
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199189
08/04/09 08:19 PM
08/04/09 08:19 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199190
08/04/09 08:20 PM
08/04/09 08:20 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199191
08/04/09 08:22 PM
08/04/09 08:22 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is the piece we cut out to clear the trans hump fit back into the car. All we will have to do is cut some extentions to raise the hump appx 1"
Re: 70 GTX-5.7 Hemi build-8-4-09 [Re: Darius] #199192
08/04/09 09:53 PM
08/04/09 09:53 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
now thats hot rodding
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: sogtx] #199193
08/17/09 07:51 PM
08/17/09 07:51 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here are some more pics of the transmission mounting. We turned a piece of aluminum to replace the rubber dampner on the w5a580. This allows us to bolt on a "U" joint which further allows us to use a slip yoke. Custom drive shaft is in progress.
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199194
08/17/09 07:51 PM
08/17/09 07:51 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
New piece
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199195
08/17/09 07:52 PM
08/17/09 07:52 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
new piece installed
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199196
08/17/09 07:55 PM
08/17/09 07:55 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
We cut holes in the cross member and "sleeved" them with 3" dia pipe for the exhaust to run through instead of having to wrap them under the frame. This will show up better in furure pics
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199197
08/17/09 07:59 PM
08/17/09 07:59 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here are 2007 Charger R/T front disc brakes on a 70 B Body with an Alterktion.Bear hubs on the MustangII spindles. Had to turn a small spacer to fit on the hubs for the difference in the rotor dia and hub dia
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199198
08/17/09 07:59 PM
08/17/09 07:59 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
closer...see the aluminum ring at the hub/rotor connection?
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199199
08/17/09 08:01 PM
08/17/09 08:01 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is the mount we had to make for the caliper...it will get "shaped" niver and cleaned up some.
Re: 70 GTX-5.7 Hemi build-8-17-09 [Re: Darius] #199200
08/17/09 08:01 PM
08/17/09 08:01 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Another view
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199201
09/25/09 08:37 AM
09/25/09 08:37 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
we got the rear brakes from the 07 Charger on the 8 3/4 axle.
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199202
09/25/09 08:38 AM
09/25/09 08:38 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
another view
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199203
09/25/09 08:40 AM
09/25/09 08:40 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
The bracket from the Charger was cut down and turned on the lathe to fit around the flange on the 8 3/4 axle housing.
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199204
09/25/09 08:42 AM
09/25/09 08:42 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Mounted on axle...se how it now fits around the flange?
Page 2 of 4 1 2 3 4
