Page 1 of 4 1 2 3 4
70 GTX-5.7 Hemi build #199165
01/20/09 06:18 PM
01/20/09 06:18 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Hi all
I started a post long ago I called MAJOR Score!!!
I cannot locate it in the search function so I thought I would just start over in here. I put all the pics on photobucket anyway since I cannot figure out how to post more than one pic per post.
Here is the plan
1970GTX to start with. I bought an insurance totalled 2007 Charger R/T that still ran and drove (rear end damage)
My plan is to take as much as I can out of the Charger and install it in the GTX. Motor, auto transmission, computers, disc brakes all around, bucket seats, it even had a satellite radio but I will use a different unit.
I bought an AlterKtion front end and a 4 link rear. I also am installing the XV frame stiffening package and one of their EFI fuel tanks.
Exterior will be primarily stock except for minor changes i.e. 16" Torque Thrust D (need 16 to fit brakesand calipers from the Charger) and the rear view mirrors will be painted ralley/race style ones from that era.
I got WWWAAAAAYYYYY delayed by the rust exposed when we media blasted the GTX. It is easier to say what REMAINS of the GTX
firewall (upper cowl replaced)
rear frame rails
floor from forward trunk seam to rear footwell seam
Roof
A pillars
inner rocker panels
inner front fenders
EVERY OTHER BODY PIECE has been replaced by AMD stuff or donor car parts!
Inside will have a custom built dash and center console and katzskin leather in blue and white
B-5 is the color with a white vinyl roof.
You can see the carnage, Charger,and progress on my photobucket site.
http://s284.photobucket.com/albums/ll40/DariusCRCKBR/
I will post updates as progress warrants. Right now it's all about plug welding and grinding at least 1500 spot weld holes!
Driving modern convenience in classic beauty
Re: 70 GTX-5.7 Hemi build [Re: Darius] #199166
02/14/09 09:54 AM
02/14/09 09:54 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I got to use the spot welder for a change....what a relief!!! Sure wish I could do the whole thing this way.
Re: 70 GTX-5.7 Hemi build [Re: Darius] #199167
02/14/09 09:57 AM
02/14/09 09:57 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Another pic. The trunk gutter was a piece of cake this way. Too bad there are some holes to plug from removing the old gutter.
Re: 70 GTX-5.7 Hemi build [Re: Darius] #199168
02/14/09 01:29 PM
02/14/09 01:29 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
WOW Darius! That's some MAJOR surgery! Looking good, though...
2 Demons...no, not my kids!
Re: 70 GTX-5.7 Hemi build [Re: 4speeds4me] #199169
04/14/09 09:03 AM
04/14/09 09:03 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Trying multiple pics in one post here.
I use AMD patch pieces for the bottoms of both sail panels.....you know the place that ALWAYS is rotted on these cars?
GREAT fit! Keep in mind I have NEVER cut a hole in a car and welde a patch back in, this was a piece of cake and the pieces fit like a glove!
I HAD some pics posted here but they got deleted???
Follow this link to see pics
http://s284.photobucket.com/albums/ll40/DariusCRCKBR/Bodywork%20Pics/
Re: 70 GTX-5.7 Hemi build * UPDATE* [Re: Darius] #199170
04/17/09 11:31 PM
04/17/09 11:31 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I was able to finally rotate my car on the rorisserie today! I was beginning to think I would never get here. Here is a link to all the pics but I will post this one now
Re: 70 GTX-5.7 Hemi build UPDATE [Re: Darius] #199171
05/17/09 10:06 AM
05/17/09 10:06 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I got my frame connectors installed. This thing is solid now!
Re: 70 GTX-5.7 Hemi build UPDATE [Re: Darius] #199172
05/17/09 10:08 AM
05/17/09 10:08 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I hung my doors and fenders for test fit...not too bad considering this car was down to a floor and roof supported by false work. The fit is workable for sure!
Lots more progress pics here
Re: 70 GTX-5.7 Hemi build UPDATE [Re: Darius] #199173
05/22/09 07:33 PM
05/22/09 07:33 PM
Arkansas
hotrod98 Offline
hotrod98  Offline
Arkansas
Looking good Darius.
I used a Lenco spot welder back when I worked for a dealership body shop. They save a lot of time. I've been trying to find a nice used one to use here at my new shop.
Can't wait to see this one finished.
1970 Superbird 4-speed, Dana, bucket seats
Re: 70 GTX-5.7 Hemi build UPDATE [Re: hotrod98] #199174
05/24/09 01:55 AM
05/24/09 01:55 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Wow, incredible looking at the resto pics.
I sure wish I had that skill set.
I can't afford this. mark
Re: 70 GTX-5.7 Hemi build UPDATE [Re: Darius] #199175
05/24/09 05:38 AM
05/24/09 05:38 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Very nice work Darius!! One thing to keep in mind is, with your frame connectors, you'll have to put a through hole in them for the parking brake cable to go through if you're installing one. Don't ask how I figured that out.
Re: 70 GTX-5.7 Hemi build UPDATE [Re: HEMICUDA] #199176
05/26/09 03:07 AM
05/26/09 03:07 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I actually have two "thru sleeves" in the cross member just inside the inner rocker on both sides and I have a "pull " wire running thru the right frame connector so I can pull my battery cable from the trunk up without having it exposed. The plan is to mount fuel and brake cables to the sides of the frame connectors since they present such a nice tall flat surface.
I'll post pics when we get around to that. There have been many discussions about that sort of thing. I even have pull wire inside both rear frame rails since I had the trunk floor out. There will be minimal wire exposed in this car when it is done.
My 30 years of remodeling work has paid off here as I am always thinking about how to conceal wire and pipe!
Re: 70 GTX-5.7 Hemi build UPDATE [Re: Darius] #199177
05/26/09 08:37 PM
05/26/09 08:37 PM
I see how you feel my pain, awesome work you are doing and I certainly think you have bigger gumbos than me.
Re: 70 GTX-5.7 Hemi build-5-30-09 [Re: Darius] #199178
05/30/09 09:07 PM
05/30/09 09:07 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Got my AlterKtion test fitted today...sweet!!!
I only had to drill 4 holes and everything else bolted right up as advertised.
GREAT job Bill in the mfg of these units!!!
I have NEVER attempted anything like this and I got it done in about 5 hours. having my car on a rotsserie made it a lot easier.
Re: 70 GTX-5.7 Hemi build-5-30-09 [Re: Darius] #199179
05/30/09 09:09 PM
05/30/09 09:09 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Another pic
Re: 70 GTX-5.7 Hemi build-5-30-09 [Re: Darius] #199180
05/30/09 09:23 PM
05/30/09 09:23 PM
Very nice Darius, just what I want but pricey. Keep up the great work.
Re: 70 GTX-5.7 Hemi build-7-2-90 [Re: ] #199181
07/02/09 10:12 PM
07/02/09 10:12 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Hi Guys
Been busy lately with work finally picking back up but I have managed to get my 4 link installed and make the car a roller again. I posted the Alterkation pics so here is a 4 link one.
Easy install and I welded it all in, I would not feel comfortable just bolying it in...although it is a pretty easy thing to do.
Re: 70 GTX-5.7 Hemi build-7-2-90 [Re: Darius] #199182
07/02/09 10:15 PM
07/02/09 10:15 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
This is not a very exciting pic in and of itself but I sure was excited to get this car back on it's own feet.
Re: 70 GTX-5.7 Hemi build-7-2-90 [Re: Darius] #199183
07/06/09 11:22 AM
07/06/09 11:22 AM
Looks fantastic!!!!!!
Re: 70 GTX-5.7 Hemi build-7-14-09 [Re: ] #199184
07/14/09 09:29 PM
07/14/09 09:29 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I got the motor/trans assembly mounted on the alterktion and installed in the car today. Here are some pics of how it looks and a few of the clearance mods worked on today.
This first one is the tunnel/hump cutout. We may have to butterfly the length of the tunnel also as the w5a580 sits rather high but will know better once we get the trans mount fabbed up
Page 1 of 4 1 2 3 4
