'72 Plymouth Satellite Battery holddown fasterner? #1991021
01/15/16 12:43 AM
01/15/16 12:43 AM
Coeur d Alene, Idaho
jimbob101 Offline OP
Am putting a '72 Plymouth back together and am trying to figure out what you call this type of mount. It is located under the drivers fender where the battery tie down strap, where can I find something like this? The hold down bolt was rusted and seized up. Thank you for your help!
-Jim
Re: '72 Plymouth Satellite Battery holddown fasterner? [Re: jimbob101] #1991157
01/15/16 06:43 AM
01/15/16 06:43 AM
Shoreline, Washington
72roadrunnergtx Offline
It’s a of type weld nut, would require some careful welding and paint work to put it back to how it was. A 5/16” caged nut may fit the square hole as an alternative if needed.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: '72 Plymouth Satellite Battery holddown fasterner? [Re: jimbob101] #1996192
01/22/16 11:38 AM
01/22/16 11:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: '72 Plymouth Satellite Battery holddown fasterner? [Re: jimbob101] #1997499
01/24/16 02:43 AM
01/24/16 02:43 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
when using washer and nut under the fender for 20 years
5549 post on old board
