Best Oil to use on 440 with stroker kit, new rebuild? #1990140
01/13/16 08:25 PM
01/13/16 08:25 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Hi was wonder what oil most guys are using on a new rebuilt 440 stroker (507). What oil weight and brand to use?
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990152
01/13/16 08:36 PM
01/13/16 08:36 PM
AndyF Offline
AndyF  Offline
If the engine was built with normal clearances then I'll say that it doesn't matter much. Use a typical factory recommended oil which would probably be a 10-30. Maybe a tad heavier in summer and a touch lighter in winter if you actually drive it in the winter. Any name brand should be fine.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990156
01/13/16 08:39 PM
01/13/16 08:39 PM
IN
ahy Offline
ahy  Offline
IN
It depends quite a bit on your engine. Does it have a flat tappet cam? If so, it needs extra zinc. How about bearing type and clearance? That affects viscosity.
A good starting point would be one of the high zinc versions of 10W30 like Comp Cams break in oil. The see how the oil pressure behaves. My personal guideline is 20 psi at hot idle on a fresh engine. If it gets there with 10W30 great. If not, step up to a higher viscosity.
I run Rotella T 15W40 + STP on my 496 flat tappet. Pressure was borderline with 10W30.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: ahy] #1990165
01/13/16 08:47 PM
01/13/16 08:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We really like the Brad Penn Oil...A lot. Shows so little wear on parts season after season. We typically run 10-40 in mild engines and 20-50 in race engines.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: Dragula] #1990223
01/13/16 09:52 PM
01/13/16 09:52 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Thanks for the help guys, appreciate it.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990236
01/13/16 10:18 PM
01/13/16 10:18 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
i run VR1 Valvoline 30wt in my 512.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: CSK] #1990241
01/13/16 10:24 PM
01/13/16 10:24 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I started and broke mine in on Brad Penn straight 30W because it is one of the highest with Zinc content. Then after that been using Brad Penn 20W-50.
Ron
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990284
01/13/16 11:21 PM
01/13/16 11:21 PM
maxfield303H1E
maxfield303H1E
another vote for the Valvoline VR1 stuff. They even now make it in synthetic too !
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990342
01/14/16 12:53 AM
01/14/16 12:53 AM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I used Joe Gibbs break in oil to break in the flat tappet cam. Then I ran Joe Gibbs Hot Rod oil 15w40. Check out there website for more detail.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: CSK] #1990356
01/14/16 01:23 AM
01/14/16 01:23 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I lost 2 hydraulic flat tappet cams last year using this oil.......
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: RJS] #1990372
01/14/16 01:42 AM
01/14/16 01:42 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
Ron
I second that Brad Penn is in my 505. Great stuff
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990380
01/14/16 01:57 AM
01/14/16 01:57 AM
On all the street and strip stroker motors I build with either a solid roller lifter or hydraulic roller lifter I use Valvoline 5W 20WT non synthetic oil thumbs There are better and worst oils out there, that Valvoline oil has worked well for me for a lot of years so far with no additives thumbs
On non roller lifter motors I use Comp Cams zinc oil additive on every oil change thumbs Lucas and Red Line sell a zinc additive also as well as a lot of other brands out there that work well so use the one you like the most thumbs
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: Cab_Burge] #1990388
01/14/16 02:05 AM
01/14/16 02:05 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I use Rotello 15/40 with a zinc additive with my stroker
Abe Lincoln
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990449
01/14/16 04:00 AM
01/14/16 04:00 AM
OT, have you fired it yet for breakin?
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: RapidRobert] #1990466
01/14/16 05:13 AM
01/14/16 05:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Valvoline VR1 is all I ever use and I have never lost a cam. Ron
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990501
01/14/16 09:49 AM
01/14/16 09:49 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
My friend had a blueprint engine from Summit. Brke it in with high zinc, then switched to synthetic. Ruined the cam in a couple thousand miles. Keep zinc in the oil....
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990507
01/14/16 10:24 AM
01/14/16 10:24 AM
jersey
Spaceman Spiff Offline
jersey
Ask the engine builder that put it together. He knows what clearances it has, and most likely has a preferred weight and brand.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990530
01/14/16 11:26 AM
01/14/16 11:26 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Broke in my old 440 with Vr1 break in oil, then used cheap rural king 10w-40 ever since. Pulled the motor after 10k for a hemi swap, looked at the flat tappet cam and lifters, still brand new. I never used a zinc additive or high zinc oil. If you break your motor in properly, you shouldn't have problems.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: batt2rm] #1990561
01/14/16 12:45 PM
01/14/16 12:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't have the race experience of some other guys on this board, however I am an Amsoil fan. They make an oil called Z-Rod which as you may guess by the name, is aimed at flat tappet engines. An oil analysis I read at one point showed it had very high levels of zinc in(higher than VR1 and Joe Gibbs), it as well as some other additive that helps prevent corrosion during long term storage.
Re: Best Oil to use on 440 with stroker kit, new rebuild? [Re: DaytonaTurbo] #1990584
01/14/16 01:16 PM
01/14/16 01:16 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
That's some good stuff. I'm thinking of switching in the GTS.
Abe Lincoln
