Page 11 of 12 1 2 9 10 11 12
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989042
01/12/16 02:23 AM
01/12/16 02:23 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This stuff is awesome, who would've thunk these little A motors would be crackin 900hp when they were bangin gears in their 340 Demons in 1971?
Mopar to the bone!!!
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989082
01/12/16 06:37 AM
01/12/16 06:37 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
tell me about it i love small blocks
Re: Cost of 900 hp in a N/A small block? [Re: one bad fish] #1989134
01/12/16 11:46 AM
01/12/16 11:46 AM
Finland
mafo Offline
mafo  Offline
Finland
Me too up
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989159
01/12/16 12:29 PM
01/12/16 12:29 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I love when they do cool things.... then I hurt something and wish I had a nice B1 low deck lol
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989256
01/12/16 02:56 PM
01/12/16 02:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By 408strokerdart
Originally Posted By fishy340
I think 408stroker went 128 in Texas air with a powerglide.
This is true, but to be fair it was killer air for here.
Can not believe nobody is inquiring about the W8 top end in the for sale section that produced these results.
That is some awesome parts at a good price, however it is an extremely narrow market... you have to have a narrow deck block and be willing to run very short pistons and rods or spin the beejebus out of a smaller displacment or find an unobtanium tall deck intake, you will still need a very expensive short block be it tall or short and you don't want to slap it on a stock block (well I do but I can afford it so thats a mute point). After someone spends $10,000 on that they are gonna think hard about an R5P7 ready to drop in with probably more potential. Someone will probably buy it at or close to you asking price but it may take a while.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989266
01/12/16 03:06 PM
01/12/16 03:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
"This is true, but to be fair it was killer air for here.
Can not believe nobody is inquiring about the W8 top end in the for sale section that produced these results"
I would love to take it off your hands but I am still knee deep in a Stratus build that seems to be never ending...
Re: Cost of 900 hp in a N/A small block? [Re: Al_Alguire] #1989274
01/12/16 03:20 PM
01/12/16 03:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
These high horsepower high rpm engines appear to have lots of durability issues and not probably the way to go for the weekly racer. A few bonzi hits in the Fall and a couple of Mopar racers a year maybe
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cost of 900 hp in a N/A small block? [Re: pittsburghracer] #1989322
01/12/16 04:28 PM
01/12/16 04:28 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
My other w8 goes 8.90 been in car from 2011 till now.
Turn it 7800 rpm have not done anything to it other than change oil.
This same engine had 70 dyno pulls before engine masters then 5 hard pulls at engine masters.
So one you don't need big RPM
And 2 if build with quality parts they can give lots of runs.
Re: Cost of 900 hp in a N/A small block? [Re: W5DART66] #1989330
01/12/16 04:41 PM
01/12/16 04:41 PM
PA.
"Little"John
"Little"John
PA.
Once again years mean nothing to me. I love and respect these Big, small blocks but the bottom line is, HOW MANY PASSES, not years. Several (fast) small block guys I know are making the switch to big blocks and the simplicity of running mid to low 8's and staying together.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989333
01/12/16 04:49 PM
01/12/16 04:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW on the heads up car the engine was just pulled at 88 passes. Still leaks down fince and compression test was good as well. It is getting destroked to drop some weight for the class we run. It makes 1054hp is shifter at 9600 and goes through just under 10,000rpm. We have broken a few valve springs along the way but are happy with it's performance. Was being freshened this yeah anyway but just saying it ran its best ever pass at the last race last year. We prefer to freshen before something breaks, So while certainly not bracket race type deal it has held up quite well with lots of RPM and really thin rings.
Re: Cost of 900 hp in a N/A small block? [Re: Al_Alguire] #1989448
01/12/16 08:17 PM
01/12/16 08:17 PM
Finland
mafo Offline
mafo  Offline
Finland
I have around 120 passes on mine now, nothing but normal maintenance,springs when needed, pac holds up very well, rods at 100 starts, now I'm going to put in new intake valves since I don't know how old they are, broke a rocker last summer, but thats it, 9000+ rpm
Re: Cost of 900 hp in a N/A small block? [Re: pittsburghracer] #1989481
01/12/16 09:07 PM
01/12/16 09:07 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
I have just under 2000, yes 2000 runs (in 2.5 seasons) on my 358 and haven't so much as adjusted a rocker arm. And yes, I buzz it every run, both in the water and throughout the run....9200 thru the lights. As for a bracket engine, I can't think of a better way to go. Oh, and thats 176 mph at 1800 lbs.
Mike
Re: Cost of 900 hp in a N/A small block? [Re: R5P7 Bantam] #1989494
01/12/16 09:33 PM
01/12/16 09:33 PM
PA.
"Little"John
"Little"John
PA.
Mike
. Pretty sure you and I talked about your engine at Norwalk as I had a chance to get one cheap. You took the time to explain some of the needed work and expense of this type of build and I decided against buying one
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989774
01/13/16 10:58 AM
01/13/16 10:58 AM
Out West
408strokerdart Offline OP
Out West
I didn't really kill mine with RPM....didn't need to. I tried shifting it at 8500 and it wasn't any quicker than 8000 RPM shifts. The norm for me was shift about 7900 and trap 8000. This is not big RPM for a 1410 bobweight short block. It's not even big RPM for a short deck big block. They can and will live a nice life with the right short block under them.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1989876
01/13/16 02:17 PM
01/13/16 02:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Brett, those are impressive numbers!!
Just curious, how much lift, how much spring?
Re: Cost of 900 hp in a N/A small block? [Re: fast68plymouth] #1990147
01/13/16 08:31 PM
01/13/16 08:31 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
.900
.880
380 1100
350 980
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1990319
01/14/16 12:09 AM
01/14/16 12:09 AM
So. Burlington, Vt.
So. Burlington, Vt.
I would think that's enough.
I see the air flow numbers stagnate at the top end of the run, which is often a tell tale of some instability in the valvetrain(I'm sure you know all that).
Was the rev limiter set well above 9000? I've forgotten to set the limiter high enough on more than one occasion.
We're you running Q16?
Dyno pulls at the 600 rate?
Re: Cost of 900 hp in a N/A small block? [Re: fast68plymouth] #1990337
01/14/16 12:40 AM
01/14/16 12:40 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Yes I saw the air flow.
I don't think it was real bad. I have seen it drop air flow fast when it starts mash the valve train up. (I might be out of port cross section😜)
Yes q16
600 rpm a sec.
They use the lower correction factor (STD) I think that's the lower one.
Was only correcting 3% ish I saw raw numbers close to 890 HP
SHE BAD👍🏻
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1990799
01/14/16 06:54 PM
01/14/16 06:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Using the fuel/bsfc numbers from the first pic, looks like 883.9 uncorrected for the 909 corrected......... That's about 2.8%.
No fluff there.
Re: Cost of 900 hp in a N/A small block? [Re: fast68plymouth] #1990845
01/14/16 08:11 PM
01/14/16 08:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
R5P7bantam I'm with you R5's are built from the main web up for RPM.
Not fair to compare to LA engines.
But, in their defense. I ran W8R3 for over 15 years. Ran Arrington headed R block before that. They are not high maintenance. I put thousand of miles and passes on the Arrington. It was built for 1000 Mile events in craftsman truck and arca. The W8 nitrous combo had a couple bugs early. Nothing serious just learning. No one was doing 457+ cubes with this stuff then. Once we got oil returning to pan if was pure joy. The 421 was turned 9,200 regularly. Once a year valve springs and aluminum rods. We hotlapped every weekend.
Look at the dyno sheets. Brett now builds more torque in the 7K range so the RPM can be run lower. Plus PAC springs outlast the triples three to one. I built all three of my engines far cheaper. Gas was also $1 a gallon. Builders wanted $30-40K back then. Keep making excuses. Truth is it's a pretty darn good combo and 200# lighter than big blocks.
To change the vibe, don't even get me started on how affordable R5P7's are at 800hp.
