340 six pack intake questions #1987642
01/10/16 03:21 PM
01/10/16 03:21 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
I found this manifold. It is marked Chrysler and has a part number. It has never been bolted on a car. Is there any way to tell if it is a very old part or a newer part similar to ones you can buy from Summit and similar places? Also am I missing something from the bottom of the intake as seen in the pics? thank you
Re: 340 six pack intake questions [Re: dan9] #1987651
01/10/16 03:30 PM
01/10/16 03:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Original.
You are missing the baffle that keeps oil from splashing on the heated exhaust crossover & the two tap in rivets that hold it in place.
Re: 340 six pack intake questions [Re: Alaskan_TA] #1987998
01/10/16 10:02 PM
01/10/16 10:02 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thank you. Is that baffle unique or can I use one from something else.
Re: 340 six pack intake questions [Re: dan9] #1988535
01/11/16 03:02 PM
01/11/16 03:02 PM
North EAST
seventy Offline
seventy  Offline
North EAST
I had one of these intakes brand new in the box from edelbrock, and it has the holes and looks the same but didnt come with the shield, I have never actually seen what the shield looks like, someone told me it comes in a 6 pack gasket set, but I have never seen one in any gasket set either.. I am curious to actually see one, the motor we did went together with out it, I was going to make one out of sheet metal but the builder said not to waste my time.
Re: 340 six pack intake questions [Re: seventy] #1988537
01/11/16 03:04 PM
01/11/16 03:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Here is a photo of one.
Re: 340 six pack intake questions [Re: dan9] #1988707
01/11/16 06:31 PM
01/11/16 06:31 PM
North EAST
seventy Offline
seventy  Offline
North EAST
Thanks TA, for some reason I was picturing something more than a flat plate. SO basically a piece of sheet metal and 2 button head rivets... pretty simple...
Re: 340 six pack intake questions [Re: dan9] #1988710
01/11/16 06:35 PM
01/11/16 06:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The edges have a slight bend, hard to see in the photo, so visualize a 'picture frame' type outline.
Re: 340 six pack intake questions [Re: Alaskan_TA] #1989235
01/12/16 01:33 PM
01/12/16 01:33 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
thanks for your help. I understand why the edges are beveled and making one is pretty simple. Do you have any idea where I could get the tap-in rivets? I guess a last resort would be to drill and tap the holes and use a bolt.
Re: 340 six pack intake questions [Re: dan9] #1989246
01/12/16 01:44 PM
01/12/16 01:44 PM
dogdays Offline
dogdays  Offline
Probably Au-Ve-Co for the rivets, many hardware stores have their boxes on the shelves.
R.
Re: 340 six pack intake questions [Re: dan9] #1989875
01/13/16 01:16 PM
01/13/16 01:16 PM
md
mopars4ever Offline
mopars4ever  Offline
md
On my stock 340 intake I removed the plate, cleaned it up and tapped the holes and installed bolts.
Re: 340 six pack intake questions [Re: mopars4ever] #2000644
01/28/16 06:38 PM
01/28/16 06:38 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
iagree Did the same. Has an intake burn a hole thru the heat crossover and had to weld it up under the plate. Made a custom plate to fit the welded patch.
Re: 340 six pack intake questions [Re: dan9] #2000928
01/29/16 01:13 AM
01/29/16 01:13 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Back in about 1975 a friend of mine bought an AAR pretty cheap because it had a "blown engine". When he tore it down he found that plate had come loose and was bouncing around on the lifters. It was a pretty inexpensive engine rebuild.
