Page 50 of 75 1 2 48 49 50 51 52 74 75
1969 B body 4 speed 23 spline serial number 9G2362C5 [Re: Cuda Cody] #2055580
04/16/16 02:28 PM
04/16/16 02:28 PM
Il
1ol74charger4me Offline
Il
NP 833, 23 spine, housing id PP833 2768 (early 1969), tailhousing 99539 for console and non console b body cars, input cover C97619 (turned to 4 1/4 size) and ball detent cover 95664. Rebuilt with new 308/307 bearings, SR 294 Synchronizers, needle bearings, seals, clips and gaskets. Cleaned and cleared over factory markings. Comes with new Brewers gasket set because I took off side cover to inspect it. When I got it I was concerned with the movement in the input shaft but sent a video and talked to Wayne at Brewers and he said there was absolutely no reason for concern. Serial number on trans is 9G2362C5 .
$700 and if shipped add $100.
Would prefer picked up in Marion Il. Can deliver to Paducah, Ky.
PM me. Will accept Paypal as friends and family.
Re: Engine and Trans Lost [Re: blewbyu] #2055808
04/16/16 10:15 PM
04/16/16 10:15 PM
blewbyu Offline
blewbyu  Offline
Originally Posted By blewbyu
Looking for my original 727 tranny for my 69 1/2 Bee part number 2892093 vin number will be 9A292038 Last seen some where in Mn, Wi, In, Il or Mi.
THANKS
blewbyu2bad@aol.com
Still Looking luck
Re: Engine and Trans Lost for 2 Different M Code Darts [Re: blewbyu] #2055809
04/16/16 10:22 PM
04/16/16 10:22 PM
blewbyu Offline
blewbyu  Offline
Missing my original tranny vin number 9B344405 from a M Code 440 Dart GTS Big Block auto tranny part number 2892093 may be in Ohio area possible "Columbus" or Caldwell Ohio REWARD paid for the return of it.
Missing original Block and tranny vin number 9B357859 from a M Code 440 Dart. Was taken out of car and put into another Dodge in Rockford Il. REWARD paid for the return.
blewbyu2bad@aol.com
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2058651
04/20/16 08:50 PM
04/20/16 08:50 PM
New York
buck0123 Offline
buck0123  Offline
New York
HEMI Trans - MOPAR 440 Engine - $1 (Cicero)
image 1
image 1image 2image 3image 4image 5image 6image 7
SYRACUSE NY CRAIGSLIST
VIN# WS23L9A144570
Hemi 4 speed A833 18 spline long shaft. Totally Rebuilt and ready to install. $2,300.00 or reasonable offer
440 Engine, Brand New Rebuild, $4,800.00 or reasonable offer
Hooker Headers Ceramic, Complete "B" body 3" SS exhaust system, both used for (2) years very good condition only about 600 miles. $500.00 or reasonable offer
Respond thru CL, Text, or Call, 315382589three
Re: Engine and Trans Lost & Found [Re: buck0123] #2076691
05/19/16 06:36 PM
05/19/16 06:36 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
Found 727 trans case PK3410672 VIN 0A168735.
1971 BS23H1B
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2078146
05/22/16 09:59 AM
05/22/16 09:59 AM
Finland
Jousi Offline
Jousi  Offline
Finland
Looking for hemi block with vin stamp
0B349196 - OB349196
340sixpax@gmail.com
Re: Engine and Trans Lost & Found [Re: Cuda Cody] #2083382
05/31/16 12:50 PM
05/31/16 12:50 PM
Dillsburg, PA
W
Wizard Offline
Wizard  Offline
W
Dillsburg, PA
I have this 4 speed transmission 23 spline. If you own the car or know of it PM me. I sold the transmission as have down payment on it and delivering in July but can pass info to new owner.
transmission stamped 0A181451
PP8333038 0159
Thnks,
Wizard
Guns, God, and Country. U.S. Veteran
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2090235
06/11/16 04:50 PM
06/11/16 04:50 PM
NH
torredcuda Offline
torredcuda  Offline
NH
2 340 engines I recently picked up, first one is a `71 long block dated 1/21/71 , last 8 of the vin - 1G240641, second one is a `71 block and crank dated 9/26/72 , vin 3B230166. Both are for sale hopefully to owner of car.
Found 340 block built March 5, 1973 [Re: Alaskan_TA] #2090830
06/12/16 07:27 PM
06/12/16 07:27 PM
California, United States and ...
Dibbons Offline
Dibbons  Offline
Looks like serial # 3G212185 (on passenger side pan rail)
Looks like serial # 3M340 X*423829X* (on driver's side of block under cylinder head)
X* = I can't determine if there is a digit in those locations or not--hard to read.
To the best of my knowledge:
3 = 1973; G = St. Louis, MO final assembly plant; 212185 = last six numbers of vehicle VIN
3 = 1973; M = Mound Road engine assembly plant; 4238 = engine built 03/05/1973; 29X engine built that day
fotos:
WS23L9A148084 18spline trans 1969 coronet r/t [Re: Dibbons] #2091005
06/13/16 12:02 AM
06/13/16 12:02 AM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
i have a 1969 hemi 4 speed trans out of a 69 dodge coronet r/t 440 car
ws23l9a148084
ogopogo69 "at" shaw.ca
Re: Engine and Trans Lost & Found [Re: moparo] #2098965
06/26/16 11:49 PM
06/26/16 11:49 PM
Lagrange, IL, USA
K
kgrandprix1 Offline
kgrandprix1  Offline
K
Lagrange, IL, USA
1969 N 96 original virgin 383 HP from air cleaner to oil pan. All OEM and complete with 65,000 orig miles running. Removed from a 1969 Super Bee.
Includes factory 4 speed bell housing, starter and fly wheel.
630-291-4440 thanks
$1,900
VIN: WM23H9A186443
Re: Engine and Trans Lost & Found [Re: Mo' boy] #2098977
06/26/16 11:56 PM
06/26/16 11:56 PM
Lagrange, IL, USA
K
kgrandprix1 Offline
kgrandprix1  Offline
K
Lagrange, IL, USA
hi
I have a N96 383 HP complete engine
WM23H9A186443
I just posted it under BB
In the case u know of someone. Pulled from a 1969 Super Bee
630-291-4440
9B287699 9B295820 & 9G258728 found 1969 727s [Re: 6bblgt] #2099266
06/27/16 01:13 PM
06/27/16 01:13 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
found big-block 727s in a friend's garage
9B287699 #2892093 from a February '69 built 383 4bbl/440HP Charger - VIN would've been:
XP29H9B287699 or XS29L9B287699
9B295820 #2892090 from a February '69 built 383 2bbl Charger - VIN would've been:
XP29G9B295820
9G258728 #2892093 from an April/May built 383 4bbl/440HP Plymouth b-body
Re: Engine and Trans Lost & Found [Re: 6bblgt] #2117384
07/25/16 02:47 PM
07/25/16 02:47 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Found 1970 727 auto trans 0A144073, supposedly out of a 383 Roadrunner.
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2120331
07/29/16 12:38 AM
07/29/16 12:38 AM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
I have 70-71 340 engine 1E225130 pm me here
69 Dart 340 block block [Re: PDR Dude] #2132448
08/14/16 01:32 AM
08/14/16 01:32 AM
blewbyu Offline
blewbyu  Offline
http://nashville.craigslist.org/pts/5659452931.html
LM23P9B182634 PHONE NUMBER 615-566-4759
Re: 69 Dart 340 block block [Re: Alaskan_TA] #2132543
08/14/16 10:08 AM
08/14/16 10:08 AM
FL
O
ollikoi Offline
ollikoi  Offline
O
FL
I have 4-speed transmission 1A176778
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2134005
08/15/16 11:30 PM
08/15/16 11:30 PM
Minnesota
Jake Offline
Jake  Offline
Minnesota
Found 440 Block for 69 Cornet R/T Ws23L9G148774
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2134007
08/15/16 11:32 PM
08/15/16 11:32 PM
Minnesota
Jake Offline
Jake  Offline
Minnesota
Lost 440 Block for 69 GTX RS23L9G182307 & Broadcast Sheet
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2140049
08/24/16 04:35 PM
08/24/16 04:35 PM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
LOST: 440 and HD727 from '71 Charger R/T- WS23U1A104636.
Feature Editor; Mopar Connection Magazine
'69 Charger- T5 Copper- 383 auto
'70 Coronet 500- F8 Green- 318 auto
'71 Charger R/T- B5 Blue- 440 auto
'71 Charger R/T- GY3 Citron Yella- 440 auto
'71 Charger Super Bee- GY3 Citron Yella- U-Code 440 4-spd
'79 Power Wagon- Red- 318 auto 4x4
'06 Grand Cherokee SRT8- Black- 6.1L HEMI auto
'08 Challenger SRT8- Hemi Orange- 6.1L HEMI auto
'12 Ram 3500- True Blue- 6.7L Cummins Auto 4x4
'17 Wrangler Winter Edition- Plum Crazy- 3.6L 6-Speed
