Re: Using magnum truck headers on a LA engine in a car
[Re: durango911]
#1989009
01/12/16 01:14 AM
01/12/16 01:14 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I typed a response for using the magnum manifolds until I read the post again and noticed it said headers. If the header route doesn't work, I'll post again with the manifold post which I did on a 73 B Body. good luck
Common sense is a flower that does not grow in everybody's garden
[Re: durango911]
#1989733
01/13/16 03:14 AM
01/13/16 03:14 AM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
I installed a pair of 360 Magnum manifolds on my old 1973 Charger 340 Rallye - they are a NICE design! LH side fit perfectly - no interference anywhere. The RH (passenger) side interfered with the trans dipstick tube. I had a new tube assembly made & all was well - no fit problems after that at all. Very easy for my exhaust installer to make a 2.25" system off the manifolds. The only mods the manifolds required was grinding the divider of the two center ports - it's a little too fat. That was very easy to grind/taper them. No gaskets either - just bolted them to the heads with no leaks.
