Page 2 of 12 1 2 3 4 11 12
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931628
10/13/15 08:47 PM
10/13/15 08:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What would you use for a block?
Mopar to the bone!!!
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931649
10/13/15 09:21 PM
10/13/15 09:21 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931653
10/13/15 09:34 PM
10/13/15 09:34 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Naturally aspirated ?
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931659
10/13/15 09:39 PM
10/13/15 09:39 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
The R3 W8 380" motor in my Valiant made just over 900 on 2 different dyno's. At 3080# I ran best of 8.67 at the Dutch Classic this past weekend. The new parts and machine work cost about $35k if you assemble yourself.
Re: Cost of 900 hp in a N/A small block? [Re: Al_Alguire] #1931667
10/13/15 09:45 PM
10/13/15 09:45 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Originally Posted By Al_Alguire
This is what I don't get....
930 HP / 580 ft-lbs with tunnel ram intake with dual holley 4 bbl carburetors
890 HP / 570 ft-lbs with single plane intake manifold and holley 4 bbl carburetor
Torque is what moves the car.
I'll stay out of it now.
Re: Cost of 900 hp in a N/A small block? [Re: ValiantRich] #1931670
10/13/15 09:47 PM
10/13/15 09:47 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Sorry, I simply don't believe it makes that much.
AndyF.........the only reason I mentioned an inline head was the price range some were throwing around, an inline was the only thing to be in the neighborhood on cost. If you are not used to building high HP motors and you know the motor that you have that makes 700hp costs X amount of dollars......it is hard for most to fathom that 200 more hp will likely triple the budget at least. I mean......it's ONLY 200hp more.........right, how tough can that be.......LOL!!!
I didn't bring Comp motors, Aussie Pro-Stock and that type stuff into the conversation, because that stuff is in another world
Re: Cost of 900 hp in a N/A small block? [Re: Al_Alguire] #1931675
10/13/15 09:57 PM
10/13/15 09:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Here is something else for guys to think about..........So lets say we believe the power claims for this splayed valve motor pictured. And lets say we know what a killer set of splayed valve heads vs an inline head flows as far as air. So if we hear of an inline motor with heads that flow way less air than the splayed ones, is making over 900HP......are we buying that claim?...........I'm not
While total air flow is NOT the be all end all number, CSA, air speed and many OTHER things also come into play, it is a pretty safe assumption to expect to make 900hp, that you will need a head that moves right at 400cfm of air. THAT thins the herd of potentials very quick
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931677
10/13/15 09:59 PM
10/13/15 09:59 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
You don't believe it because you don't know how to do it. I know what I have and the et is the proof. It can all be verified. My car is well documented.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931680
10/13/15 10:01 PM
10/13/15 10:01 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
The 19.000 dollar 360 1 was mine it's was built 5 yrs ago at min went 9.60 on 93 octane w a 950carb tti headers and 3.91 gears so I could cruise on the street....engine sold to a good fella here on the site.
The idea that 900hp can't be made w a sb tunnel ram is crazy...I seen with my own eyes one local in a duster that went 8.11 @ 173mph.
BES said personally 1000 hp pretty much guaranteed
Jeremy @ extreme will have a sb wedge out next yr w a 420 intake 1 carb that will eclipse 900 easy.Another would be Chris Uratchko.All the guys I have mentioned have theeeeee fastest sb's out there and I beleive what they say....For the effort without getting specific 40.000 would be close for one of these engines.I also wouldn't hesitate to say Bretts motor will hover within or over a true 900ish when finished.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931681
10/13/15 10:02 PM
10/13/15 10:02 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
35 to 40 for all 900hp sb's not just mopar.
Re: Cost of 900 hp in a N/A small block? [Re: ValiantRich] #1931689
10/13/15 10:13 PM
10/13/15 10:13 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Wallace says 935hp for this combo
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931691
10/13/15 10:20 PM
10/13/15 10:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That HP number is based off the ET and weight in the Wallace calculator. Wonder if basing it off the speed would yield the same numbers.
ET is how you get the car down the track. The speed is what relates to power
I know Chris, I know Tony and several others. Several times the things they are quoted as saying they CAN do or HAVE done, leaves out several key pieces of information on the full scope of the project............and I will just leave it at that
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931692
10/13/15 10:22 PM
10/13/15 10:22 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By Monte_Smith
If you read the internet and listen to guys at the track...........there is a swinging dick on EVERY street corner with an inline valve, wedge smallblock, that makes over 900HP. I have been doing this stuff for a LONG time and have NEVER seen one, be it a Ford, Mopar or Chevy. As I said, you can do it with some canted valve stuff, but it's still not REAL easy and will be at a min of 40K if you do it with all new stuff.
I have done several 434ish Chevys and Fords, with the BEST 15-18* heads you can buy. A good one will make between 840 and 880, depending on cam, compression, rotating weight, etc. I have yet to see a Mopar head that was BETTER than the best off brand, so I am going to say it can't even realistically be done with an inline head........regardless to what some dyno sheets may say to the contrary
we'll I always in joy or input always controversial and backed by a lot's of personal experience how ever only making 840to880 shows your lack of engine building experience Prostock truck ran an inline valve W8. And there are many many many comp eliminator Motors that have all achieve 900 + horsepower with an inline head. Always check history before you say something can't be done, yes it can be done and yes it is expensive. Patterson, Chris and QMP to name a few have all done it
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931693
10/13/15 10:24 PM
10/13/15 10:24 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
153 mph
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931696
10/13/15 10:28 PM
10/13/15 10:28 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Why build a 50k N/A race specific sb that makes 900hp when you can do it with a 4k shortblock and a turbo that you can drive to the track click off low 9s high 8s and cruise home. Maybe mopar guys are really that lost.
Re: Cost of 900 hp in a N/A small block? [Re: WHITEDART] #1931699
10/13/15 10:30 PM
10/13/15 10:30 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Jesus H Christ......does nobody even READ the damn posts. I implicitly said that Pro-Stock Truck and Comp motors were NOT in the discussion, because they are in a whole nother world. Was talking run of the mill, single carb, real world motors, with 15-18* wedge heads, like most people build.......NOT 10,000 rpm motors, built for clutch cars or motors for 1400lb roadsters in Comp eliminator
Seems impossible on this site, for anyone to take anything within the context of the ENTIRE discussion. They want to take ONE thing you said in ONE post, run with that comment and ignore everything else.
You guys carry on...........I'm out
Re: Cost of 900 hp in a N/A small block? [Re: ValiantRich] #1931701
10/13/15 10:35 PM
10/13/15 10:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
153 mph
Based on ET and weight, Wallace says 934hp.........based on MPH and weight, Wallace says 880hp............So now, do we know any more than we did before...........NOPE
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931702
10/13/15 10:36 PM
10/13/15 10:36 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
153mph@3080#'s is 884hp per Wallace.
Edit:your post wasn't in Monty before I posted, but I'd say he's definitely in the wheelhouse
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931707
10/13/15 10:40 PM
10/13/15 10:40 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
If you don't have a website that you talk about yourself on, you can't possibly know anything lol.
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931726
10/13/15 11:15 PM
10/13/15 11:15 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
153 mph
Moroso dream wheel says...based on ET/weight-910hp, based on MPH/weight-850hp.
Valiants aren't very aero, giving up some MPH over a different body. Stack some gear, get it to 60 and 330 on a good track can get it to ET well. Air was decent at Maple Grove early in the weekend. Just some observations. Beyond that, I'm just here spectating.
