Engine Builders, what stand do you use? #1986172
01/08/16 10:34 AM
01/08/16 10:34 AM
west palm beach, florida
modelmakerinc Offline OP
Figured this would be a better place than "General"
I have an older engine stand that is sturdy and well built but is being occupied with another project, Looking into buying another but the local Northern and Harbor Freights pieces look like junk.
Every Stand on the websites look great, but pictures usually lie.
Can you recommend a good engine(build)stand that wont break the bank but is still a quality too?
thanks Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986188
01/08/16 11:42 AM
01/08/16 11:42 AM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
I have a harbor freight stand that I welded a small brace too.had it about 6 years and It's had multiple big block Mopars on it, the last was a complete 440 that was bolted to it for about 8 months. I use grade 8 bolts from tsc with thick washers to attach it with. The wheels got a little rusty but it still rolls perfectly
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986194
01/08/16 11:53 AM
01/08/16 11:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.amazon.com/dp/B012USOOU6
I have this OTC engine stand. Pretty heavy duty, stable..... and of course, the wide legs interfere with my engine hoist.
Re: Engine Builders, what stand do you use? [Re: twayne24365] #1986196
01/08/16 11:57 AM
01/08/16 11:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 3 engine stands.. 2 are HF ones and one
I built.. the one I built I have had my diesel
engine on.. the 2 HF ones both have SBs on them..
I do weld the HF ones and I put a drip tray under
all of them(it sits on the stands)
wave
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986198
01/08/16 12:02 PM
01/08/16 12:02 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Switched to the dark side...
Re: Engine Builders, what stand do you use? [Re: JSR1485] #1986204
01/08/16 12:18 PM
01/08/16 12:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By JSR1485
I dont need the gear drive to turn over the engine
but I do like the spacers on the arms.. I'm always
looking for my 4 spacers(where the bolts attach the
engine).. I have wanted to make some steel ones to
weld on there but right now mine are alum
wave
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986210
01/08/16 12:33 PM
01/08/16 12:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I will say choose wisely. This is an older stand my brother had and when I had my old 440 on it and was moving it to the corner of my garage it broke right here. Ron
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986211
01/08/16 12:34 PM
01/08/16 12:34 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
thanks Henry
Seems like store bought stands are always too short and are getting flimsier as time goes on so, I finally built me one. Sturdy as heck and plenty tall. Made the head to fit Big Blocks since that's usually all I mess with but, I can throw an adjustable head in it for other engines. Also put the casters in the back...better for high speed turns biggrin
If I had to buy one it would probably be an OTC 1726a http://www.summitracing.com/parts/otc-1726a twocents
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986216
01/08/16 12:40 PM
01/08/16 12:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Lucky for me it did not let go when my 493 was on it. I had a block of wood under the eng to help support the front but the wood fell out when I was moving it to the corner and it broke. I myself like the one like J-body posted as we got one like that where the eng tilts back a little. And you can see in this one that broke that it did not have the plate with a hole drilled in it and the bar from the plate could have gone into the hole and been welder all the way around like that and been stronger. This stand that broke just had the plate up to the stand bar but the newer one I bought has the hole in it so the bar actually goes through the plate and is much stronger. This is the stand when I had my 493 on it as I was building it. Ron
Re: Engine Builders, what stand do you use? [Re: MoParFish] #1986227
01/08/16 12:54 PM
01/08/16 12:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have 4 engines on 4 different engine stands right now. The Blue Point (Snap-on) is very nice but my rotating engine stand from Summit is my favourite. If it opens up I immediately grab another engine to put on it. It takes me hours to clean a block for final assembly and I can rotate it to any position. Same with piston installation. Went you work alone like I do the value increases. I bought a cheap Advance Auto stand once when I needed one quickly and I won't even put an engine on it. I bought a transmission fixture from Summit and that's all I trust on it. I bought both with a 10% off coupon.
http://www.summitracing.com/parts/sum-908300ga/overview/
http://www.summitracing.com/parts/otc-7118/overview/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986236
01/08/16 01:04 PM
01/08/16 01:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have over 20 engine stands of various makes.The 1 ton four wheel are the best for stability,but the best stands we have are built in house.Stay away fron 3 wheel stands especially BB Mopars and Hemi engines.
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986260
01/08/16 01:38 PM
01/08/16 01:38 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I have a OTC Stinger and it is really sturdy, I just had a full dressed 389 Ponco engine on it.
http://www.lighttoolsupply.com/catalog/C...;categoryID=254
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986272
01/08/16 02:08 PM
01/08/16 02:08 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
This one is nice for the money. I have 1 and my dad has 2....
http://www.jegs.com/i/JEGS+Performance+Products/555/80041/10002/-1
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986277
01/08/16 02:20 PM
01/08/16 02:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
BEST stand in my opinion is an AXE. I have two
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986300
01/08/16 02:51 PM
01/08/16 02:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
OTC Stands are nice and built very well, also quite expensive. While a couple here have the larger versions I had very good luck with the smaller ones as well. We used them at the Auto Hobby Shops I ran and trust me that is an environment full of people who abuse everything. Never had a failure with one. I also have a HF one at my house that have given me good years of service, but as I am getting older(or maybe lazier)I find myself looking at the gear models I admit smile
Re: Engine Builders, what stand do you use? [Re: Al_Alguire] #1986344
01/08/16 03:58 PM
01/08/16 03:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I just purchased a new HF 1 ton capacity with the fold up leg's for ease of storage, pretty nice stand for the money and seems to be pretty well constructed, only thing I did was add a longer handle for more controll in turning the engine over, old one was way short.
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1986374
01/08/16 04:24 PM
01/08/16 04:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have 5 stands all in use all the time
Generic 2000# 4 wheel unit I use for diesels, BBs and smaller
Generic 3 wheel pice of junk I only use for V6s and 4 cyls
AC Delco 1000# 4 wheel on I shaped lower that is pretty nice, I will use it for an ocasional BB but mostly SBs
Central machine and an evercraft seem like the same things that I use for SBs and smaller. The both have the I shaped lower.
If your gonna do BB engines frequently get one with 4 wheels on 2 legs not the I shaped ones. My big 2 leg unit is real nice, it don't even flex when you set a fully dressed cummins on it and still rotates easy enough if you adjust it low enough center of gravity when you bolt it on. Some of my other stands it is hard to get them low enough you can still flip it upright with the heads on. The big one is no big deal and since it is more stable I can use a big cheater bar to flip it when it gets top heavy and not worry about the stand falling over.
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1987191
01/09/16 10:29 PM
01/09/16 10:29 PM
I picked up a stand from Northern tool, looks to be decent but I had to do some changes.
I narrowed the front beam 3" to 24" and moved the fixed welded wheels to the front and I moved the front Casters to the rear, I drilled a through hole in the rotating head to have double shear on the pin and I added a clamping bolt to the hinge point to make the stand rigid when in use.
$120, plus a couple hours of labor.
Re: Engine Builders, what stand do you use? [Re: modelmakerinc] #1987815
01/10/16 07:12 PM
01/10/16 07:12 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Typical three wheel 750 lb. rated stand. Welded a brace on a few years ago so it would handle my early hemi. Not enough to support/store a complete 440 though so I took 15 minutes and whipped up a front support that takes the stress off the rear mount. Completely removable in less than 5 minutes if necessary.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Engine Builders, what stand do you use? [Re: MoParFish] #1987844
01/10/16 07:47 PM
01/10/16 07:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nice welds. thumbs
