Need help ! 1970 Duster rocker panel molding clips ????
#1984325
01/05/16 06:14 PM
01/05/16 06:14 PM
Posts: 353 Kentucky
mopar155
Kentucky
I have a 1970 Duster that has the 2 inch wide aluminum rocker panel moldings. A few of the clips are broken and I am in desperate need of some replacements. I have searched every website that I can think of and cannot locate any. Classic Industries is now apparently repopping the moldings but not the hardware ? If anyone has any for sale or can point me in the right direction I would be forever grateful- Thanks in advance, Ron
1970 Plymouth Duster
1971 Dodge Challenger
2009 Dodge Challenger R/T
1970 Dodge Dart Swinger 340 4 Speed (Son's)
1985 Chevrolet Corvette (Wife's)
Re: Need help ! 1970 Duster rocker panel molding clips ????
[Re: mopar155]
#1984563
01/05/16 11:23 PM
01/05/16 11:23 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
I'm installing those same moldings from Classic Industries on my '69 Cuda ( I have to shorten them a bit to fit) I hunted around at various swap meets for clips and found 2 different p/n's that will work: 6003576 and 6003775 ![](http://i1314.photobucket.com/albums/t563/Superbird4406/IMG_3422_1280x719_zpsdjy8sm7i.jpg)
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: ScottSmith_Harms]
#1985217
01/06/16 10:44 PM
01/06/16 10:44 PM
RealWing
Ontario, Canada
These are what originally came with 1971 Duster Rocker moldings. The plastic clips were used from the rear forward, the metal clip was only used in the final forward location on the fender dog leg. I don't know of any reproduction source for either clip.
I have not seen a 1970 wide style in person, it may have been the same? Scott That plastic clip don't seem to be wide enough to hold the 2" wide moldings - based on a measurement I took on an original and repro molding???? Jim
[Re: mopar155]
#1985218
01/06/16 10:45 PM
01/06/16 10:45 PM
RealWing
Ontario, Canada
I have a 1970 Duster that has the 2 inch wide aluminum rocker panel moldings. A few of the clips are broken and I am in desperate need of some replacements. I have searched every website that I can think of and cannot locate any. Classic Industries is now apparently repopping the moldings but not the hardware ? If anyone has any for sale or can point me in the right direction I would be forever grateful- Thanks in advance, Ron Can you post a photo of the clips you have??
[Re: RealWing]
#1985800
01/07/16 07:47 PM
01/07/16 07:47 PM
Posts: 353 Kentucky
mopar155
Kentucky
I will take some photos and post them soon- thanks for all your help
[Re: RealWing]
#1985801
01/07/16 07:49 PM
01/07/16 07:49 PM
Posts: 353 Kentucky
mopar155
Kentucky
Realwing- the clips that you are using- did you order them from classic industries also ??
[Re: mopar155]
#1986285
01/08/16 02:33 PM
01/08/16 02:33 PM
RealWing
Ontario, Canada
Realwing- the clips that you are using- did you order them from classic industries also ?? NO- I picked them up at a swap meet. They are a little wide, so I suspect they have to be trimmed a bit to fit in the groove.
[Re: mopar155]
#1986641
01/09/16 12:37 AM
01/09/16 12:37 AM
Posts: 16,555 On the run…
BloFish
On the run…
RealWing, would you let me know how those clips work out for you?
Am looking for some clips for my 69 as well.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#1987014
01/09/16 05:53 PM
01/09/16 05:53 PM
RealWing
Ontario, Canada
Am looking for some clips for my 69 as well. Will do. It may be a while (couple of months) before I'm ready to install.
