Apache heads on a 5.7?
#1984714
01/06/16 02:40 AM
01/06/16 02:40 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
After reading the other post on Apache heads, it sounds like the Apache heads have too big of a chamber to be used on a 5.7 block? I was hoping to use a set on a 5.7 core I currently have. I also have the Apache heads, new in the box. Has anybody successfully run Apache heads on a 5.7 block, and what issues did you have?
Re: Apache heads on a 5.7?
[Re: gregsdart]
#1984853
01/06/16 01:25 PM
01/06/16 01:25 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I'm thinking the only thing you will need to do is get a cometic head gasket for a 5.7 block with a 4.10 bore. or whatever the 6.4 bore is and maybe notch the bore slightly
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Max Weg]
#1985719
01/07/16 06:38 PM
01/07/16 06:38 PM
sixpackgut
Charleston
I installed the appache heads on the freshly decked and honed block with a 0.025" gasket and measured the radial clearance at 0.032".
Max Weg cometic gasket?
[Re: gregsdart]
#2011828
02/14/16 04:40 PM
02/14/16 04:40 PM
Triple Threat
Renton Washington
Intake valve clears on my .010 over 5.7 with no head gasket.
We're going to eye brow the top of the bore slightly just because it should help unshroud the valve at low lift and provide more radial clearance.
Using a 4.100 Cometic for final assembly.
[Re: gregsdart]
#2012354
02/15/16 12:32 PM
02/15/16 12:32 PM
gregsdart
From what I understand, two things make notching the block for intake valve de shrouding of little value? First, the valve is moving away from the cylinder wall as it opens. Two, the flow on the short side radius of a port is very poor in most cases, although the Apache heads may have the best short side situation of any head on a stock motor. Still, I bet the flow difference would show very little power gain between notched and un notched bores.
[Re: gregsdart]
#2012427
02/15/16 02:10 PM
02/15/16 02:10 PM
Triple Threat
Renton Washington
Probably true, but the added radial clearance makes it worth doing IMO.
[Re: Triple Threat]
#2013064
02/16/16 12:48 PM
02/16/16 12:48 PM
gregsdart
Probably true, but the added radial clearance makes it worth doing IMO. Makes sense. Depending on where the top of the top ring is, plus .040 for keeping the ring sealed under any situation, it might get a little tough to notch the block much. I assume though that the rings have to be moved down a lot lower than a stock type piston, so valve notches can be used for bigger cams? Anyone have an idea how far down the rings have to go? I hope to bore mine to 4.000 or close.
[Re: gregsdart]
#2046054
04/04/16 08:02 AM
04/04/16 08:02 AM
gregsdart
Bump, hope fully someone can provide info on my previous post?
"Anyone have an idea how far down the rings have to go? I hope to bore mine to 4.000 or close"
