Just giving everyone a heads up that the Scat stroker kits that come with Icon pistons with 1.5 mm ring grooves will run into ring gap problems. The pistons require 0.005 to 0.007 piston to wall clearance and they measure 3.924" which requires a minimum bore of 3.929". The rings supplied with the kit are 3.927" bore and therefore way to much ring gap. As well 1.5mm rings are not very popular and a top and second for 3.935 bore is difficult to find. Just giving everyone a heads up.
Max Weg
