Re: Edelbrock victor Hemi heads
[Re: StageIII]
#1983555
01/04/16 05:32 PM
01/04/16 05:32 PM
Posts: 2,643 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I used standard pistons also. If you run near stock bore size you will have to notch the bores with a sanding cone for the big valves. They are nice.
2011 Drag Pak Challenger
[Re: StageIII]
#1984503
01/05/16 10:28 PM
01/05/16 10:28 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Did you you port the heads or run them stock? On what inch motor are they on? Edelbrock is a great vendor, but I'd still disassemble them, do a bowl blend, clean/check the valve job, and check the guide clearance. No need for porting on a street engine.
