rear shock relocate #1983593
01/04/16 06:30 PM
01/04/16 06:30 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I'm running the Mon leaf spring with the slider and Caltrac bars... I'm adding wheelie bars & the shocks are in the way... does anybody have photos on the way they've relocated their shocks.. I'm looking for some different ideas...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: rear shock relocate [Re: WHITEDART] #1983679
01/04/16 08:30 PM
01/04/16 08:30 PM
Parts unknown
590 Challenger Offline
Parts unknown
I'm not an expert but did you buy the Caltrac wheelie bars?
My understanding is the normal ones will unload the suspension. I'm not running wheelie bars but I did move shocks if it will help
Re: rear shock relocate [Re: WHITEDART] #1983680
01/04/16 08:31 PM
01/04/16 08:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How wide are your wheelie bars.. if the shocks are
in the way they must be real wide
EDIT
Looks like your gonna have to put a mount for the
bars just outside of the cast housing, inboard of
the shocks... or move the shocks.. you can add a
bracket to the shock brackets
My wheelie bars are on the shock brackets for the
lower bars and on top of the back brace for the upper
bars(8 3/4)
White.. I thought the pics were yours.. do you have
any pics of yours
wave
Re: rear shock relocate [Re: WHITEDART] #1983705
01/04/16 08:48 PM
01/04/16 08:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Cal tracks like the single bar that locates near the trunk. People that I know that have tried the standard style bars have not had good results.
https://www.calvertracing.com/calvert-wheelie-bar.html
Doug
Re: rear shock relocate [Re: dvw] #1983738
01/04/16 09:35 PM
01/04/16 09:35 PM
bean town ....Ca
W
W
bean town ....Ca
Here you go location on top is stock
Re: rear shock relocate [Re: WHITEDART] #1983754
01/04/16 10:02 PM
01/04/16 10:02 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You have "FORD" ends on your 8 3/4? OMG we have to blackball you from certified Mopar guy now..hahaha
Mopar to the bone!!!
Re: rear shock relocate [Re: 72Swinger] #1983760
01/04/16 10:06 PM
01/04/16 10:06 PM
bean town ....Ca
W
W
bean town ....Ca
1957 ford 9in smooth housing. Kind of a neat piece. Good eye look a lot like a 8 3/4.
Re: rear shock relocate [Re: WHITEDART] #1983767
01/04/16 10:11 PM
01/04/16 10:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Stand the shocks up as much as you can(top will
move outward which will help control the rear end)
you will have room for the bars.. how wide are your
bars
EDIT
Whats wrong with the brackets that are hanging down
now.. inboard of the shocks. they look perfect
wave
Re: rear shock relocate [Re: WHITEDART] #1983775
01/04/16 10:18 PM
01/04/16 10:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Well thanks for pointing that out and saving me hours of head scratching, wondering why you have so much better of a driveshaft angle than me at a similar ride height.
Re: rear shock relocate [Re: WHITEDART] #1983799
01/04/16 10:37 PM
01/04/16 10:37 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
REAL MEN DON'T NEED NO WHE....... ahhhh never mind! laugh2
Re: rear shock relocate [Re: J_BODY] #1983804
01/04/16 10:42 PM
01/04/16 10:42 PM
bean town ....Ca
W
W
bean town ....Ca
Mr.p they are 21inchs I will try to get a better pic
Re: rear shock relocate [Re: J_BODY] #1983805
01/04/16 10:45 PM
01/04/16 10:45 PM
bean town ....Ca
W
W
bean town ....Ca
j I have tried every thing believe me I didn't want to put bars on the car ....but I just can't get a handle on it.. course with the bars then I won't have to soft launch it anymore
Re: rear shock relocate [Re: 72Swinger] #1983807
01/04/16 10:50 PM
01/04/16 10:50 PM
bean town ....Ca
W
W
bean town ....Ca
the proof
Re: rear shock relocate [Re: WHITEDART] #1983811
01/04/16 10:52 PM
01/04/16 10:52 PM
bean town ....Ca
W
W
bean town ....Ca
A better view
Re: rear shock relocate [Re: WHITEDART] #1983823
01/04/16 11:19 PM
01/04/16 11:19 PM
fullmetaljacket Offline
What are those shock plates? extended shock plates for more travel?
Re: rear shock relocate [Re: WHITEDART] #1983827
01/04/16 11:22 PM
01/04/16 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Now all I need is a pic of your bars.. but the way
I would put them on is the lower would go on the
bracket you show then if it has a heim joint out
at the wheel for the upper bar I would weld a U type
bracket on the back brace so the upper bar angles
inward... thats how I did my bars.. you can do the same
thing.... you might want to move the upper shock mounts
so the shocks are more vertical to give you a bit more
room for the upper bars.. but they would clear now
wave
Re: rear shock relocate [Re: WHITEDART] #1983832
01/04/16 11:22 PM
01/04/16 11:22 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
You have brackets with bolts and can use bushings to get the right spacing. Couple of thread inserts with rod ends in the front of the lower wheelie bar assembly attached to the brackets. Distance from the axle centerline looks OK.
You can move the shocks out some if you want or leave them. Put a couple of brackets on the top of the housing brace inboard of the shocks. Use a double bracket so you can use rod ends in double shear and don't get the rod end centerline too high above the axle centerline. LH thread rod ends in one end of the top bars for height adjustment without disassembling the bars. Run the top bars from the wheelhouse up to the brackets.
Top bars don't have to be parallel with the bottoms. In fact, I prefer them to be non-parallel to give the bars some side to side stability. Cant the top brackets out accordingly. Spherical rod ends will tolerate some misalignment but make the effort to keep everything in line.
I prefer to use rod ends at all attachment points rather than a clevis on a single tab.
Re: rear shock relocate [Re: WHITEDART] #1983844
01/04/16 11:37 PM
01/04/16 11:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the only pic I have of mine but you can
see the upper bars are angled inward
wave
Re: rear shock relocate [Re: WHITEDART] #1984050
01/05/16 11:07 AM
01/05/16 11:07 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: rear shock relocate [Re: WHITEDART] #1984051
01/05/16 11:08 AM
01/05/16 11:08 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
