Re: Big block roller lifters. ..offset or not
[Re: Thumperdart]
#1983465
01/04/16 03:27 PM
01/04/16 03:27 PM
Posts: 2,449 nc
earthmover
nc
No clue I saw this 1 pulled it out and looked at it from the side it was kinda leaning back it had 2 small cracked on the side....also it didn't break in the motor just cracked ..I ended up doing that in the vise...
[Re: earthmover]
#1983472
01/04/16 03:32 PM
01/04/16 03:32 PM
Thumperdart
State of confusion
That seems like a "non stressed" area unless they were binding........I did tear apart a BB and someone put the lifters in like a small-block w/the tie bars against the block.
[Re: earthmover]
#1983477
01/04/16 03:54 PM
01/04/16 03:54 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
IMO that is a very peculiar place to have a lifter crack. Makes me think something in the valvetrain was not very happy or it was a defect to begin with. Given you found others I would guess valvetrain issue.
[Re: Charger453]
#1984151
01/05/16 02:20 PM
01/05/16 02:20 PM
Posts: 485 Central California
MoParFish
Central California
For you guys running the Comp 892 lifter, did you run them in a stock, unbushed block? I grabbed a set for extremely cheap, but wasn't sure if there's any issue with the EDM oiling hole intersecting with the main oil gallery. Some info in this thread. https://board.moparts.org/ubbthreads/ubbt...shed-block.html**Edit: Sorry just realized you posted that thread...
[Re: MoParFish]
#1984164
01/05/16 02:33 PM
01/05/16 02:33 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
https://board.moparts.org/ubbthreads/ubbt...tml#Post1906695**Edit: Sorry just realized you posted that thread... [/quote] Thanks... I'm no longer concerned with the cutaway being a problem at my intended lobe lift. What has me wondering is that 440Jim appears to have installed a restrictor in the EDM hole. This would apply to the 892s only, not the lifter I asked about in that thread. My current build is different from anything I've ever done before top end wise (-1 heads and Jesel rockers) so I'm trying to figure out what oiling issues I need to address.
[Re: Charger453]
#1984301
01/05/16 05:35 PM
01/05/16 05:35 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I'm using those lifters now in a unbushed 400 block I'm building for myself, 300+ lbs. on the seats and 800 lbs + opened. I haven't finish setting the pressures yet due to needing a cutter to cut the spring pockets so I don't know the exact pressures yet. I was told by the racer Rep I work with at Comp to use JB weld to plug one side of the oil hole going into the lifters so I did plug the outer one. I measured the depths of the oil inlet holes on both sides of those lifters and the hole on the oil galley side will be in the oil galley when the lifters are on the bottom of the lobes so it should oil the rocker arms real well Monte, which Comp Cams part numbers are you talking about for the best lifters from Comp for the .903,.904 lifter sizes?
[Re: earthmover]
#1984341
01/05/16 06:29 PM
01/05/16 06:29 PM
Al_Alguire
Las Vegas
We use the inexpensive Comp Stuff in the dragster. Never had an issue with them in any similar builds, unbushed blocks 800 or less pressure on the nose. But this aint exactly Hi HP stuff either with mild spring pressures. We run a Pac 1279? spring I believe. Right tool for the right job....
