Page 1 of 3 1 2 3
Driving the 37 and lost a wheel #1982153
01/02/16 06:22 PM
01/02/16 06:22 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
So I'm driving the 37 today to Lowes for some paint, I'm I only doing 25-30 when the truck shudders like I hit a huge pot hole then the passenger front drops to the pavement, I steer it off to the right as tire and wheel passes me. I have the original front axle and drum brakes that uses bolts instread of wheel studs. And anybody pressed wheel studs into the older hub/drum assembly? I got lucky as other than a bent dust shield the only other damage was the tire that got a huge gash in it.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1982154
01/02/16 06:24 PM
01/02/16 06:24 PM
Dreaming of the 808
Dreaming of the 808
Stripped out these hole and original style wheel bolts
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1982167
01/02/16 06:44 PM
01/02/16 06:44 PM
85086
moparpollack Online penguin-006
Lil Herman
moparpollack  Online Penguin-006
Lil Herman
85086
Well that sucks glad it was only minor damage. I bet there is a disc brake conversion that would have the new studs you need and better brakes. OK here's one for $625 plus shipping.
http://www.srpmstreetrods.com/srpm/1935-...20ac0259-p.html
Re: Driving the 37 and lost a wheel [Re: moparpollack] #1982251
01/02/16 09:15 PM
01/02/16 09:15 PM
Dreaming of the 808
Dreaming of the 808
I really don't want to upgrade the front brakes till I do the new motor and Mustsng II front end with rack and pinion steering. It looks like there is enough meat in the drum/hub (about 5/8 inch thickness) to install 1/2 inch studs. Looks like maybe B body studs might fit, I just need make sure the shoulder is not too long.
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1982390
01/02/16 11:40 PM
01/02/16 11:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That sux, you wore it out hauling all that stuff for you new shop additions, wink
Don't be the exception.
Re: Driving the 37 and lost a wheel [Re: Supercuda] #1982393
01/02/16 11:47 PM
01/02/16 11:47 PM
Dreaming of the 808
Dreaming of the 808
I got it fixed temporarily, new tire but I'm not going to drive it again till I get the wheel studs installed and different wheels, I hate these old mags. I got lucky, no suspension or body damage, just the tire
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1982394
01/02/16 11:48 PM
01/02/16 11:48 PM
Dreaming of the 808
Dreaming of the 808
Repaired
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1982400
01/02/16 11:53 PM
01/02/16 11:53 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If you were closer I would take those wheels..less tires, off your hands. biggrin (assuming they are 15"....they are still 'in' in Oz especially after a quick trip to the polisher)
And you can get studs with all various sized knurling on them of course, perhaps just drill out the drums/hubs to the minimum size to clean up the holes completely round and go from there for sizing? (Speedway sells studs and matching drill bits too from memory)
If they are 1/2" and the threads are still decent, other option would be just screw in studs perhaps as well like used on aftermarket type axles. work
Re: Driving the 37 and lost a wheel [Re: OzHemi] #1982597
01/03/16 11:31 AM
01/03/16 11:31 AM
moparx Offline
moparx  Offline
i have fixed the original bolt style hubs 2 different ways in the past. one: i used screw in studs [2 or 3" long depending on use] for aftermarket rear axles with the thin hex head or the allen style cap screw head. these were used with a drop or two of red or blue loctite. of course, the original threads were in perfect shape in the hub, plus they were both right hand thread hubs. second method was to fit for press in studs. carefully measure for the amount of thread needed for your wheel. if using thick center wheels, make sure the studs used have enough thread length to provide proper thread engagement with the nuts required for the wheels without bottoming out on the inside of the nut before the wheels torque to proper spec. if using open ended lugs, this isn't required to be looked at. next,measure the thickness of your hub or your hub/drum assembly. this will determine how long the stud knurl will need to be. make sure the knurl does not protrude more than about .010-.015" beyond the face of the assembly used because this could cause interference with the wheel sitting flat on the hub. flush, or below, is best for the knurl length. now you are ready to choose your studs. check aftermarket choices or look at the dorman catalog, and choose a stud that fits your requirements and has at least .015-.020 more diameter than your hole size in your hub[or hub/drum assembly]. for example, if you just drill out your hub threads to 1/2" to just remove the existing threads, you need a stud knurl diameter of .515" for proper press fit. if choosing other stud knurl diameters, open the stud holes to .015-.020 LESS than the knurl of your studs. this must be done on a drill press to insure your studs go in straight. next, remember to support your hub properly when the studs are pressed in to make sure, after all this, you don't bend your hub or hub/drum assembly. all this blabbing may sound like this is a major undertaking, but it is just a very simple job.
i'm glad no major damage other than a tire was caused, but i question the use of just straight bolts to secure your wheels to the hubs. i have never seen any brand of slot mag that had a 1/2" hole used with the proper nuts. they were either a shank style[most common was the 11/16" shank size] or an acorn[stock taper] style nut. if i remember, those used a 60* taper. i could be wrong, but i think you are looking at a very bad deal using straight bolts on those wheels even if you use a washer that fits inside the shank hole. just my opinion, but i think it would be best if you repair your hub/drum properly asap, or convert to disc brakes, which would be the best way to go. and before i close, if your drums are riveted to the hub, does your wheels have reliefs in them that the rivets fit into, or are the wheels just sitting on the rivet heads ? if so, that is very unsafe as well because the wheel will not have the proper support on the mounting flange, which can lead to cracking of the center. i bring this up because i have seen the results of this happen many years ago when a friend of mine bolted on a set of slot wheels on a 35 plymouth 4dr. sedan using just longer 1/2" bolts and sitting on the rivet heads. this resulted in the center breaking out of the wheel instead of just loosing it, causing damage to the front fender and running board. please get your setup fixed properly before your luck runs out ! eek
beer
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1982690
01/03/16 02:02 PM
01/03/16 02:02 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Are those wheels even designed to work with that bolt set up? Usually they need the shaft of the mag style lug nut to center them and if the center hole is to large you are just relying one that small tapered end of the lug bolt to hold the wheel on.
Re: Driving the 37 and lost a wheel [Re: moparx] #1982701
01/03/16 02:33 PM
01/03/16 02:33 PM
Dreaming of the 808
Dreaming of the 808
The thanks for the info, the wheels and original bolts were on the truck since I bought it, it was always on my to do list the change them out, now I will. I had 5 of the original wheel bolts but only found 1 on the road afterwards. I put 5 longer straight bolts on just to hold the wheel in place so I could drive it onto my lift only.
I got some Weld Wheels that if the fit I'm going to use after I install wheel studs, if they don't fit them I'm going to find a set of steel Mopar cop car wheels, either way I'm fixing this right and getting rid of the mags
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1983037
01/03/16 09:39 PM
01/03/16 09:39 PM
Dreaming of the 808
Dreaming of the 808
If they will fit I'm using these Weld Rodlites
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1983078
01/03/16 10:23 PM
01/03/16 10:23 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Problem might be those rivets? in between the studs hitting the surface of the wheel..?
Re: Driving the 37 and lost a wheel [Re: OzHemi] #1983102
01/03/16 10:56 PM
01/03/16 10:56 PM
Dreaming of the 808
Dreaming of the 808
Good spotting, I will see if I can remove them after I install studs
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1983110
01/03/16 11:06 PM
01/03/16 11:06 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
The slots probably have open areas on the back (Most I have had around, have..) so it wasn't an issue. Same goes for a lot of steel wheels, where the centers are stamped out, they end up with ridges too (how the original ones probably cleared) but the Welds or something similar might be an issue.
You "might" get lucky though and have the 5 on 4 3/4" bolt pattern on the Welds line up with the rivets so it isn't an issue but looks like they are a little close in for that off the top of my head at least.
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1983117
01/03/16 11:15 PM
01/03/16 11:15 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
I'm glad everything turned out ok....that could have been bad news..
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1983280
01/04/16 03:53 AM
01/04/16 03:53 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I'd get 1/2" thread wheel studs with larger then needed knurled ends, get the proper drill and have the new studs pressed in. I would probably install right hand thread studs on both sides. Then but the lug nuts that fit the wheels. Put some dust caps on those bearing hubs.
Sure seems like a lot of effort for something your going to dispose of in the near future, but its your money and your ride. I'd just do the disc brake conversion now. Gene
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1983310
01/04/16 10:08 AM
01/04/16 10:08 AM
moparx Offline
moparx  Offline
look close at the back side of the wheel. if there is a relief between the stud holes, you were probably sitting flat on the drum surface. if not, you will see shiny places or gouges where the rivet heads were touching. even if there were reliefs, if they weren't deep enough, you will see the same. in your last two pics above, it appears there seems to be metal transfer [aluminum] on the rivet heads, indicating the wheels are touching the rivets instead of the drum surface. look also at the holes in the wheels. i will bet there is "mashing" of the hole at the front face where the taper of the stock lugs gouged a somewhat taper into the lug nut holes. in order for those wheels to be used with the correct nuts now, the holes will have to be reamed to the correct size to remove the "mashed in" area of the holes at the top surface area. the back side of the wheels may also need attention if the rivets caused severe gouging of the mounting surface. if it is severe enough, it will require the wheel to be chucked in a lathe or bridgeport to insure a flat surface be restored. what rear do you have installed ? if stock [i can't remember], the lug bolts will also need to be changed to the proper studs as well as the drum rivet problem addressed. i hate to sound like i am picking on you,[please don't take it that way,i am not by any stretch of the imagination] but this is a SAFETY issue that affects you and others, as well as the damage it could cause to your truck. you indicate a disc conversion is in your future. now is the time to do so. i assure you, you will be time and money ahead to do so now !
beer
Re: Driving the 37 and lost a wheel [Re: moparx] #1983932
01/05/16 01:41 AM
01/05/16 01:41 AM
Dreaming of the 808
Dreaming of the 808
beer
Truck won't go back on the road till its 100% safe
Re: Driving the 37 and lost a wheel [Re: AZ_A12_BEE] #1989069
01/12/16 03:58 AM
01/12/16 03:58 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
And you or anybody else didn't get hurt! Glad to see everything and everyone is okay. Love those trucks!!
Page 1 of 3 1 2 3
