Page 2 of 12 1 2 3 4 11 12
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982704
01/03/16 02:41 PM
01/03/16 02:41 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
If the inner fenders have all the factory under coating on them it will save more than ten lbs. and if the car is rigid enough cut them off. its a start. how about bumper brackets and bumpers?
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982707
01/03/16 02:46 PM
01/03/16 02:46 PM
Up a holler, down a crick
booger Offline
booger  Offline
There's plenty of other places to save additional weight if you haven't already been into it - look at behind the kick panels, tops of the rockers under the sill plate, inner quarter panels, drilling holes in the rad support, on and on. I've got a road runner here built out of Arlen V's shop and they treated sheet metal contours like cut here lines. They even trimmed extra metal off the back of the dash frame and cut out all but the cover of the ash tray and riveted it in place. Cowl is smoothed (no vent) and the underside of the cowl is gone. Keep after it an ounce at a time and it'll add up for you eventually. thumbs
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: Challenger inner fender wells....remove? [Re: yella71] #1982722
01/03/16 03:05 PM
01/03/16 03:05 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
Under coating is long gone, I still have steel bumpers, front brackets have been thinned alot
Re: Challenger inner fender wells....remove? [Re: booger] #1982723
01/03/16 03:06 PM
01/03/16 03:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Get your self a good spot weld cutter and some spare cutter's and have at it, I took the inner panels out of my Dart and it made it a lot easier to work on and lost some weight on the front too, well worth the time and effort in my opinion, just make sure you tie the upper shock mounts to the down bar's if you haven't already. thumbs
Re: Challenger inner fender wells....remove? [Re: booger] #1982729
01/03/16 03:16 PM
01/03/16 03:16 PM
Parts unknown
Parts unknown
I haven't touched any of that. Santa did bring a fiberglass dash. You have some great suggestions. I have been nerves about chopping up the inner quarters, rockers and kick panel, do you guys remove all of it? I would love to see some pics of what people have done.
Re: Challenger inner fender wells....remove? [Re: dartman366] #1982732
01/03/16 03:22 PM
01/03/16 03:22 PM
Parts unknown
Parts unknown
That's great to hear, It's tied to the front bars but will support it better being I ran the front bars inside the wheel wells
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982748
01/03/16 03:44 PM
01/03/16 03:44 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
All your bolts cut to length?
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982783
01/03/16 04:20 PM
01/03/16 04:20 PM
Parts unknown
Parts unknown
Do people cut out the whole inner structure on the rear quarters?
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982798
01/03/16 04:29 PM
01/03/16 04:29 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982807
01/03/16 04:39 PM
01/03/16 04:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt cut anything in the rear of the car... YET..
pull as much as you can off the front end first... the
weight on the rear might be needed for traction
wave
Re: Challenger inner fender wells....remove? [Re: keefe] #1982844
01/03/16 05:41 PM
01/03/16 05:41 PM
Parts unknown
Parts unknown
Originally Posted By keefe
Thank You, That will keep me busy for a while
Re: Challenger inner fender wells....remove? [Re: MR_P_BODY] #1982914
01/03/16 07:18 PM
01/03/16 07:18 PM
booger Offline
booger  Offline
wave
Mr. P body has a good point. My car had the outside structure of the inner quarters left but the whole center was cut out and the back windows bolted in place. That way it still had some structural strength since it tied the door jamb back to the package tray, and down to the rocker. It also left places to attach the interior panel and hide it all.
The problem with my car, is that they did all that to save weight, then stick welded an old bar in it that weighed about as much as I do. I guess that's the way things were in the 70s.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1983043
01/03/16 09:49 PM
01/03/16 09:49 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Ant pic's of this scope I'm in the process of doing this to my e-body, how's it tied to the upper shock mount?
Re: Challenger inner fender wells....remove? [Re: racerx] #1983106
01/03/16 10:59 PM
01/03/16 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They are called Blair Spot Weld Cutters.. you can
buy all the parts needed to do it.. the mandrel with
spring loaded tip, the cutters.. which come in different
diameters... and you can buy the cutters single sided or
double sided.. I always use the double sided... mainly
a 5/16" diameter will work for most spot welds.. but you
might pick up a few 3/8" cutters... all you do is center
punch each spot weld then put the spring loaded tip in
the center punch divot and slowly spin the cutter while
loading up the tip.. you will get the feel for it.. you
can get the whole thing in tool supply places, maybe
Fastenal has them.. I get them from a place local to me
wave
http://www.amazon.com/s/?ie=UTF8&key...sl_7g20do305z_e
Re: Challenger inner fender wells....remove? [Re: racerx] #1983204
01/04/16 12:57 AM
01/04/16 12:57 AM
Parts unknown
Parts unknown
Are you asking how it's tied with the inner fender wells in place? I can snap some pics for you tomorrow
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1983223
01/04/16 01:32 AM
01/04/16 01:32 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Yes ...Thax you.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1983224
01/04/16 01:32 AM
01/04/16 01:32 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Cut them and don` t look back........ WAY easier !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Challenger inner fender wells....remove? [Re: chryco] #1983307
01/04/16 10:04 AM
01/04/16 10:04 AM
Parts unknown
Parts unknown
Very nice, I would love to see a closer pic of your radiator support and how you tied in the shock mount to the cage if you have one
Re: Challenger inner fender wells....remove? [Re: MR_P_BODY] #1983386
01/04/16 01:28 PM
01/04/16 01:28 PM
booger Offline
booger  Offline
[quote=racerx][quote=590 Challenger]They are called Blair Spot Weld Cutters..
Save some money and go to harbor freight and grab a handful of spot weld cutters instead. I think they're 4 bucks each. I took advice to buy the best at first, but after those cutters wore out I went with the ones from HF and they work just as good, and are also double-sided. twocents FWIW I cut a lot of spot welds, moving sheetmetal from a complete car back to the cut-up race car.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1983478
01/04/16 03:55 PM
01/04/16 03:55 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
10 lbs. is undetectable.
Boffin Emeritus
