Rear Panel, Core Support and Dash Paint? #1982219
01/02/16 08:20 PM
01/02/16 08:20 PM
VA
classiccar68 Offline OP
VA
Members, I am a junior member restoring my first MOPAR (1968 Dodge Charger R/T). For the rear panel and core support (including the grille/headlight support frame), it is my understanding that you use organisol? If so, where can I purchase the paint? For the dash, what do you apply and where can I purchase?
Thanks, Scott
Re: Rear Panel, Core Support and Dash Paint? [Re: classiccar68] #1982414
01/02/16 11:59 PM
01/02/16 11:59 PM
IN
ahy Offline
ahy  Offline
IN
In general the front grill blackout and dash paint were low gloss or satin black. I believe the orgainsal was an exterior color for hood scoops ect. Not necessarily an interior color and probably different from the grill blackout. Color codes and info for the interior colors are linked from TCP global/autocolor library.com below. They can likely mix any of the factory specs.
If this is a concurs resto ignore my advice. Otherwise, Rustoleum satin black should work fine for both the dash and grill blackout. When I did mine about 12 years ago I used Krylon but the formula has changed and not for the better.
http://images.tcpglobal.com/chips/1968-Dodge-pg02.jpg
