Has anyone put a 3.9 v-6 in an a-body? #1981236
01/01/16 05:39 PM
01/01/16 05:39 PM
Franklin CT
syleng1 Offline OP
syleng1  Offline OP
Franklin CT
I realize "why" would I want to put a v-6 3.9 from a Dakota in an 64-66 a-body?
I'm just looking to see if anyone has and what is the biggest challenges? I have a 80k f.i. v-6 that runs great and I am thinking about dropping it in with a 904. Cheap fuel injection, not too fast for my son and reliable. Plus room to turbo if we choose. Just looking for advice.
SN: I don't want to drop in a v-8 as he is a young driver. A 3.9 engine is a good engine for a young man to learn to go thru, room to drop in with ease and more power than a slant 6 but not too much to wrap around a pole God forbid. If it was just me a new 5.7 hemi would be shoehorned in.
Thank you,
Joe
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981253
01/01/16 05:52 PM
01/01/16 05:52 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
The v6 is going to be harder to drop in than a V8 as you will need to make your own motor mounts and if you want headers you will make them also. I doubt the magnum manifolds will fit an early A body, they barely fit the later A bods.
A 273 is a bolt in, don't make too much power and can easily be swapped for a 318 340 360 or even a 408 later when he is ready to lose the training wheels.
All obstacles aside I would do it if I was planning it to be the permanent engine because I like things different. I would not go through the hastle if the long term plan is something bigger eventually.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981324
01/01/16 07:11 PM
01/01/16 07:11 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
iagree With both the six cylinder and the 273 comments. Although, isn't the 3.9L similar to a 318, just 2 less cylinders (read from Allpar). The only way you'll know is if you test fit it. Although, I'd rather see the six cylinder in there.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981331
01/01/16 07:16 PM
01/01/16 07:16 PM
Kalispell Mt.
Kalispell Mt.
It is a 318 with the two rear cylinders cut out and the motor mount ears cut off.
You can not just hack two tubes off the headers as the exports are out of sequence, there are no headers off the shelf for it, the TBI/Carb manifolds bit and will hit the steering so you are stuck with the rear dump magnum manifolds and even they may not clear the firewall.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981337
01/01/16 07:19 PM
01/01/16 07:19 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I would consider a swap of this nature, but only if I was swapping the entire drive train, including the overdrive trans. I've done a 5.2/A500 swap into an '84 Ramcharger. Motor mounts are not a big issue, but I would start by putting the engine bolted to a 904 so that you can get the trans in the correct place. Then build mounts and add the OD (will need floor mods). Use the entire electrical from the donor vehicle (OBDI is easier to deal with than OBDII) and go from there...
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981361
01/01/16 07:31 PM
01/01/16 07:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what's wrong with using the slant six? they can be pumped up and still not worry about on coming telephone poles! plentiful and cheap. i know it's not what you asked but i was considering doing this for my son until he rode in a jacked up Jeep!
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981389
01/01/16 07:57 PM
01/01/16 07:57 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I'd just slap in a 318 2-barrel, a totally stock one. Honestly, it's probably still going to be slower than my 2012 1.4L, 138hp Cruze. Especially with tall gears. Makes about the same HP as a stock 3.9 Magnum anyway.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981409
01/01/16 08:17 PM
01/01/16 08:17 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I've thought about a swap like this too, just because it is different. Unfortunately, a 63-66 A body engine compartment and trans tunnel suck for roominess. They are really difficult to fit exhaust on any engine besides a Slant. A stock Slant would fit the bill for low power, and is easily hot rodded later.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981420
01/01/16 08:30 PM
01/01/16 08:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you mount the front of the V6 in the same location as the 273 then the OD trans is shifted about 4" farther forward, putting the fat part of the tailshaft in a "roomier" area, roomier being relative.
You also put the stock V6 rear dump exhaust manifolds pretty close to where a stock V8 exhaust would dump.
You also move the rear sump oil pan forward.
It any of it enough to make it fit? Dunno, haven't found a cheap enough donor yet.
Don't be the exception.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: mikemee1331] #1981735
01/02/16 01:45 AM
01/02/16 01:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I agree here. I like the idea of alternative swaps but I wonder what sort of extension you'd need for the water pump and fan to reach the radiator! Maybe an electric fan would be better? You'd gain some handling balance in terms of the center of gravity moving slightly rearward.
Keep us in the loop here, this could get interesting! thumbs
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981774
01/02/16 03:01 AM
01/02/16 03:01 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I have/had a 90 and a 91 and a 93 Magnum 3.9 here. All 3 motors still have the motor mount ears on the block. The heads look to be standard small block with the back cylinder cut off (left side). Both heads are the same. The exhaust ports have the one cylinder separate then the two ports side by side, but off the shelf headers are non-existent.
I too would bolt the motor & trans together and set them where they need to be, then build your mounts as needed. The exhaust isn't going to be any worst the putting a V8 in there would be, the back exhaust pipe on the driver side is the one that won't be there, and the back cylinder is the issue with a V8 install.
It won't be as easy as swapping in another slant 6 or a 273, but it would be a great motor for an early A body. But really Dad, anything can be wrapped around a phone pole. Sometimes the lack of power will do you in. Gene
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981842
01/02/16 11:21 AM
01/02/16 11:21 AM
Franklin CT
syleng1 Offline OP
syleng1  Offline OP
Franklin CT
Good Morning Guys and ladies.
Thanks for the advice. Honestly the car has been a slant 6 since 66' and after my offenhouser dual 1 bbl swap and a bunch of money into the engine it is still a slow and lack of power 6 cylinder that hates this new fuel we have to buy here in New England at the pump. MY boy wants a Fuel Injected v-6 with a turbo. I think he is on to something as this is the way to go as a v-8 is heavy, hot on a summer day and no room for mods without modifying the car which is way to clean and straight to cut her up. Maybe secretly he wants to take on Crow from the 405... LOL! he's 13.
I agree with Poorboy as lack of power is not good but as a Dad, I can put anything in the car "I" want. It is not for me but my son who has little skills at 13 years old. By building what he thinks is cool (turbo v-6) together he will respect the car more than if I just do it and give it to him.
I personally don't want to just drop in a 273 or 360 like every other car out there. If I did, I would had just bought a crate engine and transmission with an 8 3/4 and drop it in. 2 or 3 car shows and the car just blends in and there is no pride for my son. The slant 6 in the car looks really cool now but just plain is boring even with the 2 air cleaners and HEI ignition. I get there are slant 6 people out there who love them to death. No offence, but there is better technology out there and I want to be part of that technology but it needs to be Mopar; no Chevy engines for me. Sadly the Mopar Fuel injection has not changed for the better in a lot of years. I'm only going to do the 3.9 because I got this 80k engine for free and it runs great. I thought of a v-6 3.3 from a mini van but have no idea how to hook up a transmission and the computer programming needed to shift it. As MoPar fans we are limited to the luxury of this like our Ford and Chevy friends. We have to run the alcohol added fuel from the pumps here in New England and it makes a mess of carbs, tanks and fuel lines. I want a just pull up to the pump and "fill it up" mentality. I will have to modify the fuel tank and that's ok - I own a welding and heavy equipment repair shop. The mounts and welding and fabrication is not an issue. I thought about the new V-6 from a wrecked Challenger or Charger but the prices for the wrecked units and no aftermarket conversion electronics makes it more trouble than its worth.
Also, just for the masses: If I reverse the manifolds from a older v-6 (pre 1994) I can dump the exhaust in front of the engine and mount a turbo in front of the engine (low hood clearance of the early a-bodies) and then one single pipe back over the driver side of the engine out the back of the car. Room for an inter cooler and plumbing loosing the 2 front cylinders. I've done some quick measurements and a turbo and electric fan will clear - tight but no issues and NO inner fender cutting.
Thank you for your help.
Joe
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1981894
01/02/16 12:35 PM
01/02/16 12:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No offense dude, but we're all running the alcohol fuel these days, and if you're still having trouble with fuel lines and such, you're doing it wrong.
I would sooner turbo the slant with an aftermarket efi system than look at a 3.9.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: DaytonaTurbo] #1981996
01/02/16 03:20 PM
01/02/16 03:20 PM
dogdays Offline
dogdays  Offline
What a bunch of naysayers! Wimps! You'd think he's trying to repaint the Mona Lisa.
It's a great idea and I think I'd start by looking at Dodge Dakotas and how they're set up. Maybe drop the A-body on a Dakota frame, even.
But put the engine in the place where everything fits the best and go from there. If you have the fab capabilities it will be made to work. Even moving the radiator back or forward has been done before, no big deal.
The kid is 13? That's 3 years minimum to get it all together, should be long enough.
Alcohol fuel? Everybody gripes about it, why shouldn't he have that luxury too?
Just do it.
R.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: dogdays] #1982094
01/02/16 04:25 PM
01/02/16 04:25 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I run mine on the same Ethanol blend out here in CA. Mine runs fine. I know that I'm not lucky or special, just that many people claim that CA gas is even worse than what people get in other states.
A return system in your fuel line can make up for the fast evaporation rates.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1982142
01/02/16 06:01 PM
01/02/16 06:01 PM
Kalispell Mt.
Kalispell Mt.
Gonna need to fab an oil pan or at least run the steering linkage through the sump, doubt your gonna find a pan to bolt right in as the only one ever made is rear sump.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1982184
01/02/16 07:01 PM
01/02/16 07:01 PM
Park Forest, IL
Park Forest, IL
No offense sir, but if you can't get an N/A Slant to run right you'll have a disaster with a turbo/efi V-6.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1982199
01/02/16 07:18 PM
01/02/16 07:18 PM
Manitoba, Canada
Manitoba, Canada
Well first step would be to get the v6 running, before worrying about the turbo. In the past when doing swaps like this I have bolted the engine to the trans and bolted it down by the trans mount and fabbed my motor mounts from there. That sounds like something the OP can do himself. The exhaust he can figure out after he at least gets the engine bolted down. He's got a lot more room in that engine bay to turbo the slant than he does to turbo that V6, but that's up to him.
I actually think a hi-po 273 would be a really fun build for this car and would certainly be a good opportunity to teach your son how engines work.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1982646
01/03/16 12:45 PM
01/03/16 12:45 PM
Franklin CT
syleng1 Offline OP
syleng1  Offline OP
Franklin CT
Good Morning MoParts fans,
This is what I was trying to prevent. Long paragraphs OFF topic from what I need... just info If any one had done it and what to look out for NOT opinions on why I can't or what you think is good for OUR car.
First off I've had a slant 6 in this car since 1989 when I bought the car from the first owner and there was no alcohol fuels. I have no issues with getting it to run on E-85 or alcohol fuels just to be clear. I just am trying to prevent World war 3 with the Slant 6 guys and not insulting them. They are the many that keep this hobby going. I've run cam 2 in both my cars since 2005 at now $10.00 per gallon because of the fuel issues from sitting. Honestly the Barracuda gets like 1,000 miles a year and the Demon last year got 50 miles. Even with additives and draining the tanks I just want to get in them and drive and the non-ethonol fuels help me get to that ride faster with less issues / less stress. My issue is the slant 6 is not worth building in my eyes. I tried to upgrade it and it still is a slant 6 and nobody even cares to look under the hood at shows. It is very disappointing. Turbo a slant6? SURE, but why? The intake and exhaust ports are still too small. Some do it, yes but I can drop a small block in with a carb and make twice the HP and 1/2 the work load, just like the masses. Even a MPFI 3.9 stock makes 30-50 hp more than a six by it's self. Less weight than a /6 and more room for other stuff. Even having the weight back of the engine compartment is an advantage.
So I thank everyone who has replied with good information. I appreciate it. Those who gave me reasons not to do it, thank you for your opinion but we are still going to try it Anyhow. As for my son Anthony... I will do the best I can to help you accomplish your goals. This is a good example of life and how others will try to stop and crush your dreams and goals because of their short comings. You my son have vision and drive - all I can say is "Go for it." I am there to help -Love Dad.
Re: Has anyone put a 3.9 v-6 in an a-body? [Re: syleng1] #1982780
01/03/16 04:18 PM
01/03/16 04:18 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
A bit more exotic swap would to be mating a Mitsubishi 2L turbo to a BUILT Baby 904 from a 78-84 Challenger/Sapporo and with all the computer controls for that Mitz motor you'd have up to 500 + Horse. Very light, small in width and full of power. Set the computer controls down and have 175 to 200 HP and as your driving just tweek the settings and POOF Raging bull in a china shop.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
