Re: 48RE slip yoke ?
[Re: OzHemi]
#1981602
01/01/16 11:26 PM
01/01/16 11:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Spline count is the same but the outer diameter is bigger.
[Re: OzHemi]
#1981940
01/02/16 01:42 PM
01/02/16 01:42 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Not sure if it's larger as Dave said but somewhere along the line they changed the angle the splines are cut on. Same count and size but they won't go on.
[Re: OzHemi]
#1982210
01/02/16 07:50 PM
01/02/16 07:50 PM
HotRodDave
Kalispell Mt.
There is no angle on them, with the tail housing off the yolks slide on and off both out put shafts.
To be sure you can slide a 727 ylok in there, I bet there is a big gap between the bearing and yolk surface.
If you want I can look in my stash and see if I have one.
[Re: OzHemi]
#1983122
01/03/16 11:22 PM
01/03/16 11:22 PM
HotRodDave
Kalispell Mt.
The 47RE and down uses the 727 yolk, only the 48RE uses the bigger outer diameter yolk.
[Re: HotRodDave]
#1983127
01/03/16 11:26 PM
01/03/16 11:26 PM
HotRodDave
Kalispell Mt.
If you want to use the 727 yolk you can just swap the OD housing, all the guts are easy to swap no special tools needed (unless you want to dissasemble the OD direct clutch pack), make sure you swap out the big ball bearings in the case also. I can sell a 2wd OD housing with the 727 output bearing size for the price of scrap and shipping.
[Re: HotRodDave]
#1983326
01/04/16 11:20 AM
01/04/16 11:20 AM
Guitar Jones
If you want I can look in my stash and see if I have one. I think around '90 the spline changed from an involute to a convolute spline, they have the same spline count but do not interchange. If you look inside the yokes side by side you can see the difference. You are correct that the 48 has a larger outer diameter.
[Re: OzHemi]
#1984695
01/06/16 02:07 AM
01/06/16 02:07 AM
HotRodDave
Kalispell Mt.
Sorry but I dug through my pile and have no 48RE yolks. I do have over 100 output shafts from 727, 48RE, 44RE, RH... and they all have the same splines, I just don't see any difference and the 727 yolk and 47RE yolk slide on all of em... must be getting blind in my old age.
[Re: HotRodDave]
#1986959
01/09/16 04:15 PM
01/09/16 04:15 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A while back I went to the local Pick-N-Pull to get a driveshaft for a project I'm involved in. 727 shafts are rare in the yards nowadays and I needed one with Spicer 1330 u-joints to mate up to the 727 and Ford 9-inch combo. Previous threads here stated that all the 46RH/RE slip yokes would fit a 727.
I chose a shaft from a 2000 Durango with a 46RE, I pulled it myself and it slid right out of the trans with little effort. When I got it home and tried to plug it into the 727 it wouldn't go so I tried several of the bare 727 output shafts in my stash...still wouldn't go. The end of the 727 output shaft is ever so slightly tapered and this allowed the RE yoke to just barely start but not slide in.
The pics below show the yokes and their splines. It appears that the spline angle on the two yokes is different. (the yoke with the paper tag is the 46RE)
[Re: John_Kunkel]
#1987601
01/10/16 03:17 PM
01/10/16 03:17 PM
Guitar Jones
Yep, I went through this trying to fit a large joint 904 style yoke. Chrysler changed the pressure angle of the splines across the board awhile back.
