Re: Elephant Ears...where to buy?
[Re: Hot 340]
#1980823
01/01/16 01:51 AM
01/01/16 01:51 AM
Posts: 4,648 aotearoa
rebel
aotearoa
i have Comp Engineering motor plates, they fit well but if i had more HP i'd probably look for thicker ones. I like CE's plates as they allow plenty of room top mount things like Alternators, vac pumps, coils & relays.
[Re: jcc]
#1980887
01/01/16 03:28 AM
01/01/16 03:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I never liked the ears... they would always come loose being that they moved being 2 separate plates.. they hinged on the bolts ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1980895
01/01/16 03:50 AM
01/01/16 03:50 AM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
I never liked the ears... they would always come loose being that they moved being 2 separate plates.. they hinged on the bolts Totally agree!
[Re: markz528]
#1980906
01/01/16 04:17 AM
01/01/16 04:17 AM
rebel
aotearoa
I never liked the ears... they would always come loose being that they moved being 2 separate plates.. they hinged on the bolts Totally agree! I don't know about your racecar maintenance but we do regular "spanner checks", & constantly check things for tightness. maybe it's your plate design, but mine fit in between the chassis rails. once they've been installed & tightened, there's nowhere for them to go anywhere even if they did somehow get loose.
[Re: MR_P_BODY]
#1980955
01/01/16 11:32 AM
01/01/16 11:32 AM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
I never liked the ears... they would always come loose being that they moved being 2 separate plates.. they hinged on the bolts I agree Mr. P.
[Re: MR_P_BODY]
#1980957
01/01/16 11:50 AM
01/01/16 11:50 AM
dartman366
Mt. Vernon, Ohio
I never liked the ears... they would always come loose being that they moved being 2 separate plates.. they hinged on the bolts Over the years i have heard that same complaint from other people, had one fellow tell me that once he added engine limiters for the fore and aft movement and that helped the problem alot. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Hot 340]
#1980959
01/01/16 11:55 AM
01/01/16 11:55 AM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Anybody know of a supplier for old school bb/hemi a body two piece elephant ears? Ive been digging online and can come up with much. I see some from comp engineering, not sure how well they work. Not interested in a big motor plate. Sent you a PM for what you are looking for
[Re: Hot 340]
#1981091
01/01/16 02:51 PM
01/01/16 02:51 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I had a friend that was breaking tailshaft's because the 'ears' were allowing movement so he switched to a full motor plate. The ears that Rebel uses look like they have enough mounting points to do a better job for sure, I actually like that idea for my car as it would eliminate the thickness of the plate which puts the water pump snout only 2.75 inches from my radiator, it's just a street car anyways. I do love my AR-Engineering plate though, it works good and looks really nice.
[Re: Hot 340]
#1981093
01/01/16 02:53 PM
01/01/16 02:53 PM
ProSport
Akron, Ohio
After looking at it more, I might be wrong. Rebel, do your ears go between the block and water pump? Hard to see on my phone.
[Re: Hot 340]
#1981179
01/01/16 04:18 PM
01/01/16 04:18 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Two piece mounts will NEVER be as rigid and solid as a one piece plate................doesn't matter if you tighten the bolts after every run
A BBM does not have bolt holes in the bottom of the block to help hold the plate in place, like Chevy motors do, so clamped behind the water pump mounts is it, that's all you got. Gives a scissor effect as MrP says and it always will. The holes are never precision, so they come off and put them back on, they may or may not be in the same place. If you ever need a screwdriver to line them up with chassis.........SOMETHING moved. May not be big deal for many, but the two piece ones do move around
