2008 Sebring transmission problem #1979393
12/30/15 04:19 PM
12/30/15 04:19 PM
N.E.Ohio
P
Polarabill Offline OP
P
N.E.Ohio
I have a 08 Sebring convert with a 4 cylinder/auto with 110,000miles on it that is my winter beater. In the last 3 days it has shifted into neutral as I was driving. Both times it was under normal acceleration. Traveling about 60mph and it just goes into neutral(not the shifter,just the trans)I let up on the gas and it goes back into gear and is ok till the next time. Any ideas? I don't want to get into expensive tranny rebuilds but if it a minor problem I'll deal with it.
This would be so much easier if I knew what I was doing...
Re: 2008 Sebring transmission problem [Re: Polarabill] #1979496
12/30/15 06:20 PM
12/30/15 06:20 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Obvious item first.change out oil and filter and scan for codes..
Re: 2008 Sebring transmission problem [Re: AARCONV] #1979503
12/30/15 06:23 PM
12/30/15 06:23 PM
N.E.Ohio
P
P
N.E.Ohio
I will start there
Re: 2008 Sebring transmission problem [Re: Polarabill] #1979549
12/30/15 07:32 PM
12/30/15 07:32 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
check fluid level.
Re: 2008 Sebring transmission problem [Re: moretoys] #1979728
12/30/15 11:19 PM
12/30/15 11:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By moretoys
check fluid level.
I agree. Sounds like its low on fluid. If it was something else and set a code many times that will put the tans in Limp mode and it would lock in second or third gear and would not shift until you shut it off and restart it and if it was not a hard code then it would shift again. Course low on fluid can cause the code of "Loss of Prime" and may eventually set a code. Ron
Re: 2008 Sebring transmission problem [Re: Polarabill] #1979793
12/31/15 12:26 AM
12/31/15 12:26 AM
N.E.Ohio
P
P
N.E.Ohio
I feel pretty stupid not thinking of the obvious,I will check the fluid level first thing in the morning and go from there. Thanks guys.
Re: 2008 Sebring transmission problem [Re: Polarabill] #1988118
01/11/16 12:55 AM
01/11/16 12:55 AM
N.E.Ohio
P
P
N.E.Ohio
Update on tranny issue. It seems that it is an electrical problem. Codes indicate one of 3 problems. Ignition switch, computer or wiring. More later
Re: 2008 Sebring transmission problem [Re: Polarabill] #1990400
01/14/16 02:25 AM
01/14/16 02:25 AM
N.E.Ohio
P
P
N.E.Ohio
After another computer scan, we are thinking it is nothing more than an old weak battery. A malfunctioning aftermarket remote starter may also play a role but that is uncertain as it only showed up as an alarm arming code and the car does not have an alarm system. The remote starter activates the electrical system but won't start the car. Will see what happens with a new battery.
