Re: 500 inch Mopar Build - Which intake to go with? [Re: D200] #197990
01/20/09 10:39 AM
01/20/09 10:39 AM
Chandler, AZ
cirrusaero Offline
cirrusaero  Offline
Chandler, AZ
I have a 440 punched out to a 500 stroker, Forged crank form 440 source, Indy EZ heads and an Edelbrock dual plane intake. I had a Demon 750 but on the engine dyno the carb was defintly too small. We looked at some of the Demon RS series carbs but went with a Braiswell 1050 in the end. I don't have the cams specs handy but it's around 600.
OK my opinion, get an Indy Dual plane. and get the thing port matched with the heads. That should get that skinny Cuda into the 10's as a street reliable car. ( Don't get the Edelbrock manifold since you would have to mill off the heat transfer passages anyay, well depending on which valley pan you buy)
68 Charger 605 Hemi, Keisler 5spd, Pro-touring
66 Coronet 2dr post
66 Satellite
Re: 500 inch Mopar Build - Which intake to go with? [Re: cirrusaero] #197991
01/20/09 12:56 PM
01/20/09 12:56 PM
I would use a the Eddy Performer RPM intake and a 1/2 adapter to mount the carb or port the top of the intake and drill and tap new holes for the carb mounting holes this intake flat works on the street and at the strip
Re: 500 inch Mopar Build - Which intake to go with? [Re: D200] #197992
01/20/09 08:27 PM
01/20/09 08:27 PM
richmond indiana
I
ichsam Offline
ichsam  Offline
I
richmond indiana
the Indy 440-2d works good on the 500 inch , low profile at only 5.25 inches , will bolt on your stealth heads & you can open the same intake up to the max wedge size in the future if needed
Re: 500 inch Mopar Build - Which intake to go with? [Re: ichsam] #197993
01/20/09 09:42 PM
01/20/09 09:42 PM
AndyF Offline
AndyF  Offline
Sam,
Tell Russ he needs to do a 4500 flange version of your dual plane intake. There is enough material there in the casting, just machine them with the other pattern when you have the intakes on the VMC.
Might be a good idea to offer them with the runners opened up to MW size on the CNC. The intakes have to be in the VMC anyway to do the surfacing.
Re: 500 inch Mopar Build - Which intake to go with? [Re: AndyF] #197994
01/20/09 10:06 PM
01/20/09 10:06 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
great intake, you can use mine (already Maxied)(PLEASE!) to build the prototype
http://www.youtube.com/watch?v=jd8GeXYYkKU
I've got a worked 1000HP on my 517 already and she's using it all up and want's a bit more!! Needs a dommy (that'll fit under the stock hood )
WIZE
In Car:
Re: 500 inch Mopar Build - Which intake to go with? [Re: Streetwize] #197995
01/20/09 10:22 PM
01/20/09 10:22 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
M-1.
Sounds like your combo is fairly similar to mine. I don't have it installed in my '69 Barracuda yet, but guys here say low 11's to high 10's shouldn't be a problem.
If you are street driving it, I'd go with a smaller carb for more response and better manners. I have a new 950 HP for mine, but probably would've done fine with an 850. 1050 sounds like a little much, IMHO.
My combo:
440 block, .040 over, 4.15 crank
Hughes HEH4650BL Hydraulic cam, 108 lobe separation, specs are at 1.6:1 :
intake .606 lift at 246 duration
exhaust .614 lift at 250 duration
Edelbrock Performer RPM heads, 84 cc
Harland Sharp 1.6:1 rollers
Ross 99903 pistons, 11:1 at zero deck
Ported Mopar M-1 intake
Holley 950 HP
MSD 6AL, MSD Pro-Billet distributor
Re: 500 inch Mopar Build - Which intake to go with? [Re: ichsam] #197996
01/20/09 10:26 PM
01/20/09 10:26 PM
300by500 Offline
300by500  Offline
I had a 440-2D, nice intake but will still require a hole in the hood on an A-body/RB motor...not much shorter than the M-1...I'll bet you know the exact height difference, dont-cha'?
Re: 500 inch Mopar Build - Which intake to go with? [Re: 300by500] #197997
01/21/09 09:01 PM
01/21/09 09:01 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
an M1 with a dominator on a low deck fits under a stock charger hood.
Re: 500 inch Mopar Build - Which intake to go with? [Re: Joshs68] #197998
01/26/09 08:44 PM
01/26/09 08:44 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
I have a 68 Cuda fastback project also
440 stroked to 505 with 440 source internals , about 11-1 . with Muscle Motors cnc'd Stealth heads
Victor Intake , 950 Holly ,
I hope it fits under my Hemi hood scoop
MSD ,
CompCams XTQ294S-8 solid lift cam
.567 & 579 lift
.264 & .270 dur @ .50
2" CPPA chassis headers
Mufflers undecided yet , but I want LOUD side exit in front of the rear tires
727 tranny and I'm looking for a converter now
I hoping for 600 horses or so and 10's
Dana 60 , 4.10 gears and my tub work is still ahead of me yet
It's just a fun weekend street machine to take to the track a few times a year
Re: 500 inch Mopar Build - Which intake to go with? [Re: DonnieLawson] #197999
01/26/09 09:18 PM
01/26/09 09:18 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
TM7
Mopar Performance
Re: 500 inch Mopar Build - Which intake to go with? [Re: AndyF] #198000
01/26/09 09:25 PM
01/26/09 09:25 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Here is the M1 intake with a 4500 flange. This is on my 505 motor that has CNC ported Mopar heads. 680 hp with a street roller cam. This setup would make a killer street/strip combo if you can afford the race gas!
those push loc hoses are great. King Kong couldn't pull'm loose.
Re: 500 inch Mopar Build - Which intake to go with? [Re: DonnieLawson] #198001
01/26/09 09:36 PM
01/26/09 09:36 PM
Southern Maryland
preddy Offline
preddy  Offline
Southern Maryland
MSD ,
.567 & 579 lift
I run that same cam and a very similar setup. I think you'll like it... Mine is a 493 (11:1) with MCH Eddy's, 3:91s in a 4000lb Road Runner and I'm running high tens. I don't have a Victor though. I think thats a better intake than the Wieand Team G I'm using.
Re: 500 inch Mopar Build - Which intake to go with? [Re: preddy] #198002
01/26/09 10:04 PM
01/26/09 10:04 PM
Middletown , Ohio
Middletown , Ohio
Not to hijack the thread or anything ...........
But do you have video or soundbites of your combo running ?
Mines not together yet , I'm dieing to hear one with the same cam and cubes
Re: 500 inch Mopar Build - Which intake to go with? [Re: DonnieLawson] #198003
01/27/09 12:02 AM
01/27/09 12:02 AM
Southern Maryland
preddy Offline
preddy  Offline
Southern Maryland
I do. It's not the best quality but it works.
http://home.comcast.net/~69rdrnr/100_1707.mov
About the original thread, I don't think low 11s or high 10s will be a problem with that combo My intake is considered to be an older, less efficient design and yet I have to be making > 600 HP. Last October, I raced a Chevelle with a 572, 620 HP Chevy Crate motor and beat him with a 10.90 to his 11.19. His 60' was a 1.50 to my 1.52 and I was pulling away from him at the other end. I know I'm heavier than him so all things being equal, I'm making at least as much HP as he is, if not more - with an intake that's not as good as a Victor or an M1. So you should be ok, with either.
I've tried several carbs and settled on a Holley 4150, 950 CFM. I bought a used one from a friend for $300 and it's been great.
