Re: Small block electric water pumps
[Re: rickraw]
#1979446
12/30/15 05:24 PM
12/30/15 05:24 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I have the morose with the blue motor. Still works great after 13 yrs. I have more shroud to water pump motor clearence with the morose. Street or strip?? How much hp ???
[Re: rickraw]
#1979455
12/30/15 05:39 PM
12/30/15 05:39 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Street & strip. About 720 ponies. Is there a difference between the blue and the silver pumps ?????
[Re: rickraw]
#1979515
12/30/15 06:38 PM
12/30/15 06:38 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
Off hand, I don't know. U can make a call to find out. I run a wizard rad/w 4 pullers. Temp never goes over 190 no matter how hot it gets. Runs about 170 on the open highway. I just ordered the same one from Wizard cool , how do like it?
Switched to the dark side...
[Re: RAY1969CARS]
#1979555
12/30/15 07:45 PM
12/30/15 07:45 PM
JSR1485
Seaford Delaware
I talk to the Guys there and they said it should work out fine for my race car, As they say you get what you pay for , big difference in cost from a BS brand radiator and theirs
[Re: JSR1485]
#1979561
12/30/15 08:00 PM
12/30/15 08:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I talk to the Guys there and they said it should work out fine for my race car, As they say you get what you pay for , big difference in cost from a BS brand radiator and theirs For a race car your going WAY OVER KILL.. a 45gal pump is over kill but thats what I have.. it even works great on the street... I run a the fan that most of the guys run on the street(it the chevy unit thats all in one)cant remember the 3 letters of it and with a adjustable thero switch on the fan so it never sees over 200*.. if I want lower I can have it come on earlier.. but I have zero problems with 200* EDIT Its a HHR fan/shroud assem.
[Re: RAY1969CARS]
#1979568
12/30/15 08:16 PM
12/30/15 08:16 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
"IF".... I had to do it over again I would go with the TANK MOUNTED Mezier water pump. You would then get Andy F's front plate and only have two AN lines running to the front of the engine. This would free up TONS of room on the front of the engine for mounting fans etc... http://arengineering.com/products/water-manifolds-for-small-block/I currently run the Mezier like the CSR pump shown above on both of my small blocks, but have the fan mounted in front of the radiator due to space limitations. Having a "divorced" water pump would remedy that and still give ample room to access the crank for adjusting/checking valve train. Woulda..coulda..shoulda.. this is my iron head 360 and my W8 has the same pump for ease of switching between mills... as you can see, if I had one or two fans on the radiator it would be very tight. So tight that it would probably require them to be removed to crank the engine over with my long breaker bar. Maybe something you wouldn't require on a street/strip car, but right now I want the room to work.
[Re: RAY1969CARS]
#1979620
12/30/15 09:00 PM
12/30/15 09:00 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I run the ProForm electric pump with a Summit brand radiator. I drive it on the street and do not even have to turn my front mounted electric fan on. Never goes over 190*. Been running that way for about 4 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: RAY1969CARS]
#1979708
12/30/15 10:58 PM
12/30/15 10:58 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I agree that the radiator mounted Meziere would be awesome with Andy's setup.
I have a Meziere on mine and have been very happy. It did go down after a 14 years but I can't complain about that. They repaired it very quickly for a great price.
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#1980218
12/31/15 03:46 PM
12/31/15 03:46 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
On my Dart I used the Meziere pump and milled the timing cover flat so I don't need the plate. This gave me about 3/4" more room. On my new project I really like the remote pump and using the motor plate threaded for fittings http://www.summitracing.com/parts/mez-wp116shd
"Just a Bracket car dressed up like a streetcar"
