Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#1984235
01/05/16 04:17 PM
01/05/16 04:17 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I like this topic. I'm considering the alum cable. lol I'm making fiberglass molds for my car right now. Going to make a roof and 1/4's next. I'm trying to get this going before spring. I have about a $100 in the mold so far.
[Re: Thumperdart]
#1984278
01/05/16 05:19 PM
01/05/16 05:19 PM
FastmOp
Hot Rod Ridge
I don't make parts for other people, they would complain and want stuff for free. LoL I just like working on my junk to get it faster. I made a hood a couple years ago. Car is a 1st gen Avenger. Here is the mold after I peeled it off the trunk, the 1st pic is of the gel coat. The green stuff peeling off the mold is PVA mold release. the car
[Re: Thumperdart]
#1985731
01/07/16 06:46 PM
01/07/16 06:46 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my front wheel and tire weighs 26 lbs. wondering how that compares to others. I run a convo pro with nexen VW tire
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1985789
01/07/16 07:34 PM
01/07/16 07:34 PM
Thumperdart
State of confusion
my front wheel and tire weighs 26 lbs. wondering how that compares to others. I run a convo pro with nexen VW tire I lost quite a bit of wt goin to et fronts over 165 radials.......
[Re: Triple Threat]
#1985977
01/08/16 12:30 AM
01/08/16 12:30 AM
fullmetaljacket
I have somewhere in my notes how much my old and new front tire/wheel combos weighs in at. These were the very first Centerline stealth wheels I saw at centerline's booth at SEMA. They are light in weight, but I'm afraid the bias-ply tire weighs more than the wheel itself.
Note the the stealthy light alloy wheel lug nuts, Dr. Diff aluminum drum hub. This just before I added the titanium wheel studs themselves.
[Re: fullmetaljacket]
#1986304
01/08/16 02:57 PM
01/08/16 02:57 PM
Thumperdart
State of confusion
I agree about those tires being heavy and I know my 165`s were compared to the 26" ET fronts I run now.......
[Re: Thumperdart]
#1987133
01/09/16 09:00 PM
01/09/16 09:00 PM
fullmetaljacket
While I have been slacking on progress with the influx of work and other matters, I managed to get off one side of my titanium rear shock plates while in Detroit and had it welded this morning at Accurate. Though it is a handsome metal after welding and waiting for the titanium shock bolt to be installed aside from final file finishing, it only came in at 1/2 pound lighter than the stock unit. One pound total for both sides. That is probably because I decided on 5/15 thick titanium plate instead of the more weight friendly stock 3/16 plate thickness. I just want to make sure it all holds together back there during launches. What say ye?
[Re: Thumperdart]
#1987171
01/09/16 09:43 PM
01/09/16 09:43 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You guys are way over my budget. I guess I will have to stick to my diet and A bodies. LOL
[Re: Thumperdart]
#1987259
01/10/16 12:17 AM
01/10/16 12:17 AM
sixpackgut
Charleston
I had a goal of 2 lbs per week and by the next Drag Week, I should be down 100
Last night I just went over the 50 lb mark.
[Re: Thumperdart]
#1987441
01/10/16 11:30 AM
01/10/16 11:30 AM
Posts: 2,709 NJ central
Scamp408
NJ central
[quote=sixpackgut]my front wheel and tire weighs 26 lbs. wondering how that compares to others. I run a convo pro with nexen VW tire I lost quite a bit of wt goin to et fronts over 165 rad ials....... [/quote. Aprox how much? And can you run them with a radial out back? I lost 7 lbs going from the wide valve covers back to stk.
