Milodon External pick-up oiling systems which one do you use
#1976779
12/26/15 09:31 PM
12/26/15 09:31 PM
dartman366
Mt. Vernon, Ohio
single line, dual line, swinging pick-up or static, which one do you use on your BB stroker? reason I ask is there are so many variations it hard to determine what is the right set-up or what is overkill for a 512 lo deck stroker that I don't plan on revving above 7000/7200, rpm also plan on using the Milodon Super Stock pan #31470
Re: Milodon External pick-up oiling systems which one do you use
[Re: barracudabob]
#1976861
12/26/15 11:20 PM
12/26/15 11:20 PM
dartman366
Mt. Vernon, Ohio
When I researched it, I was told that a single line was good to 6500 RPM, after that a dual line setup was recommended. my thinking is that a single external line is going to be better than any internal set-up.jmo
[Re: dartman366]
#1976873
12/26/15 11:43 PM
12/26/15 11:43 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I run a dual line swinging pickup setup and a trap door oil pan. I've turned my old 440 to 7,000 rpm, never had an issue. I don't care if it's overkill, I know it works.
[image][/image]
[Re: sgcuda]
#1976877
12/26/15 11:47 PM
12/26/15 11:47 PM
Posts: 4,212 Mo.
racerx
Mo.
I run a dual line swinging pickup setup and a trap door oil pan. I've turned my old 440 to 7,000 rpm, never had an issue. I don't care if it's overkill, I know it works. Same here been on the car sense 06 no problem so far.
[Re: dartman366]
#1976941
12/27/15 01:52 AM
12/27/15 01:52 AM
Posts: 44,229 Bend,OR USA
Cab_Burge
I ran the mopar stock 3/8 pickup 1970/71 440 6 pak pickup for the OEM 1970/71 Street Hemi 440 6 pak 6 quart oil pan in my 518 C.I. low deck stroker motor. I had to keep the oil level at or above the add mark to race it in a 1/4 mile, if I let it get down a quart the oil pressure would drop some after I let off in the 1/4 mile If was less than a 1/2 quart down it was fine I shifted that motor at or above 7000 RPM in 1st and 2nd gear and crossed the finish line at or above 6500 RPM the 10.5x31x15W M/T slicks, it would cross the finish line at or above 7000 RPM with the 315x60x4 ET Street Radials I ran real loose oil clearances(.0035+ on the rods and .004+ on the mains, I used the narrow full groove Federal Mogul truck main bearings(4094M) also I oiled the rockers full time by grooving the #4 cam journal to make sure the valve springs got plenty of oil to keep them cool due to the solid roller cam spring pressures, above 680 lbs opened and 300+ on the seats That motor saw a lot of slow street driving and a lot of laps at the local tracks, 1/8 mile and 1/4 miles. My main message is the that oiling system served me fine I've used Milidon external oiling system before and since then also but there not needed for the application your building in my opinion
[Re: dartman366]
#1977045
12/27/15 11:42 AM
12/27/15 11:42 AM
Posts: 748 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
what size bearing clearances are you planing on running? I run a duel line on my 512, but I have some loose bearing clearances.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#1977079
12/27/15 12:44 PM
12/27/15 12:44 PM
Posts: 1,403 Columbus Ohio
Moore & Moore
Columbus Ohio
We run dual line with remote oil filters on our cars. Either Indy or Milodon pump covers. You might consider a Charlie oil pan because they are lower profile. The Milodon 31470 oil pan hangs low and with some of the pit areas around here you have to be careful. I would also go with a 9 or 10 quart pan also. I like the swinging pickup. If you can find an accumulator (3 quart) might consider one of them also.
Jack
[Re: camdog440]
#1977504
12/27/15 10:21 PM
12/27/15 10:21 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
The late Jeff Kobylski, founder of Modern Cylinder Head, once said he used a single line system up to 9500 rpm. He was talking hemi, though.
I have a -16AN to a single line static. I don't like it. My oil pressure goes to zero after hitting the brakes after the finish line.
[Re: Sammy]
#1977544
12/27/15 10:54 PM
12/27/15 10:54 PM
Posts: 4,649 aotearoa
rebel
aotearoa
I have a -16AN to a single line static. I don't like it. My oil pressure goes to zero after hitting the brakes after the finish line. you need either a deeper pan or an Accumulator.
[Re: dvw]
#1978375
12/29/15 01:24 AM
12/29/15 01:24 AM
Posts: 12,595 Great Neck,LI,new york
hemi-itis
I have the Milodon pan as per the MOPAR bible.Twin line swinging pick up with 2 remote filters and an accumulator.
[Re: dartman366]
#1978524
12/29/15 12:30 PM
12/29/15 12:30 PM
Posts: 13,648 Marion, South Carolina [><]
an8sec70cuda
Milodon single external w/ static pickup on my hemi. Cross the stripe at 7400 rpm making over 1,000 hp. Milodon 21815 oil pump w/ a factory cast iron oil pump cover that I ported. 440 source fab'd aluminum oil pan. I put a hole in the side of the pan and used Milodon's static pickup.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
