Re: Coming to a strip near you, 25.5 (70) Challenger
[Re: 6PKRTSE]
#1986567
01/08/16 10:40 PM
01/08/16 10:40 PM
Posts: 4,579 Motor City
6PKRTSE
Motor City
Dang, looking pretty good if I say so myself. Thanks for loading them Jeff.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: racerx]
#1986651
01/09/16 12:50 AM
01/09/16 12:50 AM
6PKRTSE
Motor City
can't remember.....what hood were in the plans for this project? And will those carbs clear it? Going to be poking the Dominators thru a shaker hood with a modified opening by widened and lengthening the opening to clear. Then come up with something for a scoop. Either modified drop base shaker bubble or other type of scoop like lexan or something???
[Re: 6PKRTSE]
#1986820
01/09/16 11:46 AM
01/09/16 11:46 AM
Posts: 4,075 Mo.
racerx
Mo.
[quote=racerx]can't remember.....what hood were in the plans for this project? And will those carbs clear it? Going to be poking the Dominators thru a shaker hood with a modified opening by widened and lengthening the opening to clear. Then come up with something for a scoop. Either modified drop base shaker bubble or other type of scoop like lexan or something??? [/quote Sounds like a plan.
[Re: racerx]
#1986965
01/09/16 04:29 PM
01/09/16 04:29 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Beautiful work...wish it were mine!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 6PKRTSE]
#1987043
01/09/16 06:54 PM
01/09/16 06:54 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I thought Hemi's didnt like Nitrous?
Mopar to the bone!!!
[Re: 6PKRTSE]
#1988349
01/11/16 12:17 PM
01/11/16 12:17 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#1988460
01/11/16 02:55 PM
01/11/16 02:55 PM
6PKRTSE
Motor City
I have sprayed everything. It is a whole different tune on a Hemi than usual. I believe 8SEC70CUDA sprays his HEMI also with no issues.
[Re: cudaman1969]
#1991957
01/16/16 02:19 PM
01/16/16 02:19 PM
6PKRTSE
Motor City
It is an O'Reilly Motorsports AlterKation kit. I am happy with it so far, all bolt on. Just have to drill out some spot welds & grind off the old factory upper bump stops off of the frame rails.
[Re: 6PKRTSE]
#1992091
01/16/16 06:00 PM
01/16/16 06:00 PM
Posts: 8,337 fredericksburg,va
cudaman1969
fredericksburg,va
It is an O'Reilly Motorsports AlterKation kit. I am happy with it so far, all bolt on. Just have to drill out some spot welds & grind off the old factory upper bump stops off of the frame rails. Thanks I'll look it up. Do you know what the difference is between 25.3 & 25.5 with the bars? I'll buy one or the other spec sheets but still undecided as of now.
[Re: 590 Challenger]
#1992324
01/17/16 12:18 AM
01/17/16 12:18 AM
cudaman1969
fredericksburg,va
I did the 25.3 and bought both books. It's been a few years now but all I remember off the top was the ceiling has an x instead of just a single cross bar. Gussets on the door cross bars, specs for the rear half. Thanks, never expect to go that fast but while I'm there might as well do it all. Definitely easier now. I guess the book will say what size bars are needed where. One more thing, if I buy the 25.3 book will it show the 25.5 specks, then what's needed to make the former.
