Page 12 of 18 1 2 10 11 12 13 14 17 18
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986490
01/08/16 08:27 PM
01/08/16 08:27 PM
Parts unknown
590 Challenger Offline
Parts unknown
New tubular K Frame, Tubular A arms & rack.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986497
01/08/16 08:33 PM
01/08/16 08:33 PM
Parts unknown
Parts unknown
Mock up Hemi in. I think I am going to need a scoop. LOL. Plumbing Nitrous & heads assembled.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986499
01/08/16 08:38 PM
01/08/16 08:38 PM
Parts unknown
Parts unknown
The Hemi nearing completion.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986503
01/08/16 08:45 PM
01/08/16 08:45 PM
Parts unknown
Parts unknown
Repainting rear valance & installing new re-chromed bumpers.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986512
01/08/16 09:02 PM
01/08/16 09:02 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Your doing a great job.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986561
01/08/16 10:36 PM
01/08/16 10:36 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
can't remember.....what hood were in the plans for this project? And will those carbs clear it?
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986567
01/08/16 10:40 PM
01/08/16 10:40 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Dang, looking pretty good if I say so myself. Thanks for loading them Jeff.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986629
01/09/16 12:10 AM
01/09/16 12:10 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks amazing!!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: racerx] #1986651
01/09/16 12:50 AM
01/09/16 12:50 AM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Going to be poking the Dominators thru a shaker hood with a modified opening by widened and lengthening the opening to clear. Then come up with something for a scoop. Either modified drop base shaker bubble or other type of scoop like lexan or something???
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986820
01/09/16 11:46 AM
01/09/16 11:46 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Originally Posted By 6PKRTSE
[quote=racerx]can't remember.....what hood were in the plans for this project? And will those carbs clear it?
Going to be poking the Dominators thru a shaker hood with a modified opening by widened and lengthening the opening to clear. Then come up with something for a scoop. Either modified drop base shaker bubble or other type of scoop like lexan or something??? [/quote
Sounds like a plan. thumbs
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: racerx] #1986965
01/09/16 04:29 PM
01/09/16 04:29 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Beautiful work...wish it were mine!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1986973
01/09/16 04:38 PM
01/09/16 04:38 PM
Kirkland, Washington
Pacnorthcuda Offline
Good God that's COOL!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1987043
01/09/16 06:54 PM
01/09/16 06:54 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I thought Hemi's didnt like Nitrous?
Mopar to the bone!!!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1988349
01/11/16 12:17 PM
01/11/16 12:17 PM
an8sec70cuda Offline
Man, that's NICE!!!!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: an8sec70cuda] #1988460
01/11/16 02:55 PM
01/11/16 02:55 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I have sprayed everything. It is a whole different tune on a Hemi than usual. I believe 8SEC70CUDA sprays his HEMI also with no issues.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 590 Challenger] #1991905
01/16/16 01:21 PM
01/16/16 01:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Who's k-frame kit
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: cudaman1969] #1991957
01/16/16 02:19 PM
01/16/16 02:19 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
It is an O'Reilly Motorsports AlterKation kit. I am happy with it so far, all bolt on. Just have to drill out some spot welds & grind off the old factory upper bump stops off of the frame rails.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1992091
01/16/16 06:00 PM
01/16/16 06:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks I'll look it up. Do you know what the difference is between 25.3 & 25.5 with the bars? I'll buy one or the other spec sheets but still undecided as of now.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1992107
01/16/16 06:43 PM
01/16/16 06:43 PM
Parts unknown
Parts unknown
I did the 25.3 and bought both books. It's been a few years now but all I remember off the top was the ceiling has an x instead of just a single cross bar. Gussets on the door cross bars, specs for the rear half.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 590 Challenger] #1992324
01/17/16 12:18 AM
01/17/16 12:18 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks, never expect to go that fast but while I'm there might as well do it all. Definitely easier now. I guess the book will say what size bars are needed where.
One more thing, if I buy the 25.3 book will it show the 25.5 specks, then what's needed to make the former.
