Page 1 of 4 1 2 3 4
833 O.D. bolt pattern...one bolt slightly off? #1976890
12/27/15 01:19 AM
12/27/15 01:19 AM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics....
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1976907
12/27/15 01:56 AM
12/27/15 01:56 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Wow that's off by alot. Did you buy the Passon 4 speed overdrive?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1976934
12/27/15 02:46 AM
12/27/15 02:46 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The case for my son's 18-spline left the factory with OD gears in it. It fits fine. Not sure what's up with yours.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: ProSport] #1976960
12/27/15 03:16 AM
12/27/15 03:16 AM
Central Valley, CA.
Central Valley, CA.
I wish...lol...no this a plain 833 OD my boys are putting in a 64 dodge Sweptline pickup they are building. I just found another old post where someone found something similar and just slotted the hole in the trans....
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1976966
12/27/15 03:35 AM
12/27/15 03:35 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What bell housing are you using? What motor?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977044
12/27/15 12:38 PM
12/27/15 12:38 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've run a lot of stick cars, and have never seen that before. But I don't see any reason why you couldn't just slot the hole and bolt it up without any issues. Just make sure that you have the right retainer diameter against the bellhousing openning. The retainer opening keeps the trans from moving up and down/left and right. The bolts supply the clamping force to the bellhousing. It will be fine.
[image][/image]
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977209
12/27/15 04:20 PM
12/27/15 04:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Looking at it it looks like it was brokne and welded back on.Im 1/2 blind but that looks like weld bead near the case.Just open up the hole or leave the bolt out.Rocky
Chrysler Firepower
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977224
12/27/15 04:49 PM
12/27/15 04:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That don't look like any A833 I ever saw, for reference:
Don't be the exception.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977239
12/27/15 05:06 PM
12/27/15 05:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Supercuda now that I look more I agree.Never saw one with that bolt/plug thing in the pic.I was just looking at the hole that looks like an ear was welded on.Rocky
Chrysler Firepower
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Jim_Lusk] #1977241
12/27/15 05:08 PM
12/27/15 05:08 PM
Central Valley, CA.
Central Valley, CA.
It's a hydraulic style SB bell from a late 80's to early 90's d150. It has the 435 and 833 bolt patterns. And sized for the large OD retainer. I also checked the bell's bolt pattern to a BB '67 B-body bell by linin up the holes and it appears to match. So the hole on the trans itself seems to be what's off.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977243
12/27/15 05:10 PM
12/27/15 05:10 PM
Central Valley, CA.
Central Valley, CA.
I'll look again...but in person it looks like it is just cast that way.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: therocks] #1977245
12/27/15 05:13 PM
12/27/15 05:13 PM
Central Valley, CA.
Central Valley, CA.
I'm new to 4-speeds...but I hope your wrong...haha. Someone gave it to me as a 833 OD. Let me go snap some more pic and maybe you guys can help me figure out what I have.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977250
12/27/15 05:18 PM
12/27/15 05:18 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Are there any stamped or cast numbers on it?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: stumpy] #1977253
12/27/15 05:32 PM
12/27/15 05:32 PM
Central Valley, CA.
Central Valley, CA.
On the little machined pad is stamped:
PP 833 5 31 83
And cast in:
C-13546 B 04A2183
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: stumpy] #1977255
12/27/15 05:34 PM
12/27/15 05:34 PM
MoPar Offline
MoPar  Offline
What bell do you have there ? the bottom of the bell should be flat to accept the lower inspection cover and where are the bell holes to attach it to the block ?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977258
12/27/15 05:40 PM
12/27/15 05:40 PM
Central Valley, CA.
Central Valley, CA.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: MoPar] #1977263
12/27/15 05:42 PM
12/27/15 05:42 PM
MoPar Offline
MoPar  Offline
Please pull that trans off the bell and give us a pic of the bell to trans mating surface on the bell also the bell to block mating surface on the bell.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: MoPar] #1977269
12/27/15 05:48 PM
12/27/15 05:48 PM
Central Valley, CA.
Central Valley, CA.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977271
12/27/15 05:54 PM
12/27/15 05:54 PM
Central Valley, CA.
Central Valley, CA.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977273
12/27/15 05:56 PM
12/27/15 05:56 PM
MoPar Offline
MoPar  Offline
skip the trans it is a plain jane o.d. 4 speed, get us pics of the bell.
Page 1 of 4 1 2 3 4
