1970 440-6 correct choke thermostat housing #1977041
12/27/15 11:31 AM
12/27/15 11:31 AM
Connecticut
W
wayno56 Offline OP
wayno56  Offline OP
W
Connecticut
Which is the correct Holley housing number? I have a number 32 cover plate and 43 assembly but the rod seems too long to attach to the choke lever on the carb. I see that year one sells one with the number 97 stamped on it. Also does anybody know the correct length of the rod. Any help would be appreciated. Thanks!
Re: 1970 440-6 correct choke thermostat housing [Re: wayno56] #1977078
12/27/15 12:43 PM
12/27/15 12:43 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Re: 1970 440-6 correct choke thermostat housing [Re: wayno56] #1977107
12/27/15 01:17 PM
12/27/15 01:17 PM
Connecticut
W
wayno56 Offline OP
wayno56  Offline OP
W
Connecticut
Thank you,very good link.
