How to quickly identify 8 3/4 rear axle housing? #1976998
12/27/15 10:31 AM
12/27/15 10:31 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Today, I'm heading to look at an 8 3/4 axle housing for an A-Body with a friend. Are there specific features that can be identified to distinguish between an 8 1/4 vs 8 3/4? I believe the back of the center section between a 7 1/4 and an 8 3/4 are significantly different, but I'm not sure of differences between 8 1/4 and 8 3/4. Where is the part number located? On the shaft? Or on the outside area of the bowl where the center section attaches?
Re: How to quickly identify 8 3/4 rear axle housing? [Re: vinnyd76] #1977003
12/27/15 10:44 AM
12/27/15 10:44 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
Re: How to quickly identify 8 3/4 rear axle housing? [Re: vinnyd76] #1977007
12/27/15 10:53 AM
12/27/15 10:53 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the quick response! Very helpful info!
Re: How to quickly identify 8 3/4 rear axle housing? [Re: vinnyd76] #1977027
12/27/15 11:52 AM
12/27/15 11:52 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Is it under the car or out? Make sure it's the proper width for an a body. They are the most narrow and in high demand, so they bring a premium. I don't know the width off the top of my head. Does it have drums and backing plates? They are unique for an a body. How about the third member? Look on the drivers side casting numbers. Look at the last three numbers. It will most likely be a 741 in an a body. That it the least desirable because it has the smallest pinion. It could be a 742 or a 489. See if it turns freely. If it does, have a buddy hold one axle with a bar between the studs and you try and turn the other. If you can turn it, then it's not a sure grip. I looked at one just a month ago and was told it was a sure grip. Performed the test and they both turned. He was asking 350 for a 69 Super bee rear that he thought was a sure grip. No sale for me that day. Good luck. Stay warm today!
Re: How to quickly identify 8 3/4 rear axle housing? [Re: fastmark] #1977129
12/27/15 02:35 PM
12/27/15 02:35 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
There is no center section... just housing. The housing is out of the vehicle. I'm pretty sure my friend stated it had axle shafts with backing plates and drums.
Thank you once again for the feedback!
Re: How to quickly identify 8 3/4 rear axle housing? [Re: vinnyd76] #1977174
12/27/15 03:31 PM
12/27/15 03:31 PM
CA
crackedback Offline
crackedback  Offline
CA
Housing only should measure ~52 5/8" flange to flange
Axles and brakes should be 4" bolt circle.
Re: How to quickly identify 8 3/4 rear axle housing? [Re: vinnyd76] #1978142
12/28/15 09:31 PM
12/28/15 09:31 PM
michigan
cosgig Offline
cosgig  Offline
michigan
The center to center on the spring perches should be 43" for an A body housing, and it would've only come with small bolt pattern axles, unless changed out for aftermarket! Don't be fooled by the 65-67 B body housing, which is only an inch wider than the A body unit, but has large bolt axles! Also, the brake line distribution block on a 1969 and earlier A Body axle will be up on the center hump a little, whereas the 1970 and later unit will have the block down on the drivers side axle tube a bit! This may cause a problem with the length of the rubber hose needed!
Re: How to quickly identify 8 3/4 rear axle housing? [Re: cosgig] #1978153
12/28/15 09:47 PM
12/28/15 09:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There are two different A-Body housings too. The brake "T" on the housing moved after 1970 so brake lines will be different, just for future reference. The best way is to bring a tape measure and use the measurements listed above especially if it is just a housing. The early B-Body housing is 1" different in the frame rail spacing. There was never a big bolt A-Body 8-3/4, but plenty of people change brakes and axles.
JB Rhinehart, Realist
A-Body's RULE!
Re: How to quickly identify 8 3/4 rear axle housing? [Re: vinnyd76] #1978556
12/29/15 02:13 PM
12/29/15 02:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Should be pretty easy to tell an 8 3/4 from a 8.25 or a 7.25 , the 8 3/4 doesn't have a bolt on cover on the rear ...
As far as telling one from the other ... tape measure ...
