Rocker shaft oiling? #1976718
12/26/15 08:08 PM
12/26/15 08:08 PM
W
Wagonman1967 Offline OP
W
So I have a 67 440 block with 906 heads. I am priming the oil system and have 45psi on a gauge. I am not getting oil to the rocker shafts. FYI the shafts and rockers are old Isky ductile units. I pulled the hold down at the # 4 bolt and see no oil. Dose the cam need to be in a certin position to line up with the holes in the cam bearing? Hopefully I dont need to pull the heads. Shouldent the hole in the head go all the way to the galleys in the block? Am iI missing something?
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Rocker shaft oiling? [Re: Wagonman1967] #1976721
12/26/15 08:13 PM
12/26/15 08:13 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Rotate the crank and you should get oil up to the rockers unless the rocker shafts are blocked.
Re: Rocker shaft oiling? [Re: Wagonman1967] #1976722
12/26/15 08:15 PM
12/26/15 08:15 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep. There are two crank positions that send oil up to the heads--one for each side.
Re: Rocker shaft oiling? [Re: Pacnorthcuda] #1976731
12/26/15 08:37 PM
12/26/15 08:37 PM
turn dampener till the slit is at TDC (on #6 compression) & preoil. turn dampener 3/4 of a turn back CCW & preoil again. 3/4 of a turn is 17.082" and you can cut a thin strip of white notebook paper to that length to use as a ruler
Re: Rocker shaft oiling? [Re: Wagonman1967] #1976788
12/26/15 10:42 PM
12/26/15 10:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
and put a towel or the rocker covers over the shafts to avoid oil all over the fenders (damhik).
Re: Rocker shaft oiling? [Re: Wagonman1967] #1976815
12/26/15 11:19 PM
12/26/15 11:19 PM
W
W
Thanks Guys will try the suggestions and report back.
2001 Dodge Ram 4wd
Re: Rocker shaft oiling? [Re: RapidRobert] #1976834
12/26/15 11:34 PM
12/26/15 11:34 PM
W
W
[quote=RapidRobert]turn dampener till the slit is at TDC (on #6 compression) & preoil. turn dampener 3/4 of a turn back CCW & preoil again. 3/4 of a turn is 17.082" and you can cut a thin strip of white notebook paper to that length to use as a ruler [Yup That did it thanks Rapid Robert/quote]
2001 Dodge Ram 4wd
Re: Rocker shaft oiling? [Re: Wagonman1967] #1976838
12/26/15 11:38 PM
12/26/15 11:38 PM
W
W
With that technique I have oil all over the top end now. Thanks.
2001 Dodge Ram 4wd
