Best alternative to a TruTrac #1975902
12/24/15 11:07 PM
12/24/15 11:07 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Guys, I have an 83/4 with a TruTrac that Im not happy with due to the noise it makes whilst coasting and cruising nor the way the rear wheels wobble like a loose front wheel bearing.
Im looking for suggestions to a viable alternative that will give me simialr performance.
Car is a E Body, 408/727 (solid roller cam, W2 closed chamber heads, FAST EFI, 11.5:1 CR and so on, makes around 600 at the flywheel), its mostly a street driven beast with the occasional run down the strip or round a circuit. I dont want to go spool and Im thinking a cone or clutch type LSD may or maynot work with the HP, a Locker would be probably ok but is noisy round corners, any suggestions???
I love the way the TruTrac works as such and that its maintenance free and so on, just hate the noise, people that ride with me the first time look at me like the back end of the car is about to fall out!!!
Re: Best alternative to a TruTrac [Re: crash520] #1975908
12/24/15 11:16 PM
12/24/15 11:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sounds like it is not set up properly or has something wrong with it?
I have a trutrac and it is excellent with no issues... (not in an 8.75" but same idea)
Re: Best alternative to a TruTrac [Re: OzHemi] #1975910
12/24/15 11:21 PM
12/24/15 11:21 PM
IN
ahy Offline
ahy  Offline
IN
The clutch type is a good alternative - I run one which is quiet and effective. That said I think the Truetrack a great differential and also wonder if something is wrong with yours.
Re: Best alternative to a TruTrac [Re: crash520] #1975912
12/24/15 11:22 PM
12/24/15 11:22 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
I have a new replacement still in the box that is worse than the one I had in the car, the problem is the side gear inside of the center can move in its housing, you grab the rear wheel at 3/9, wobble it like you would to check a front wheel bearing and, well not good
[img]http://i3.photobucket.com/albums/y84/crash520/th_IMG_0121.mp4[/img]
Re: Best alternative to a TruTrac [Re: crash520] #1975913
12/24/15 11:25 PM
12/24/15 11:25 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
eaton claim they are within spec!!! I'm working with Cass on this, he is a great guy and is still arguing the fact with them
Re: Best alternative to a TruTrac [Re: crash520] #1975915
12/24/15 11:26 PM
12/24/15 11:26 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Re: Best alternative to a TruTrac [Re: ahy] #1975930
12/25/15 12:21 AM
12/25/15 12:21 AM
NY usa
540challenger Offline
NY usa
I have a trutrac in my 8 3/4 ebody and I don't have any of your problems. Good luck I hope Eaton makes it right.
Re: Best alternative to a TruTrac [Re: crash520] #1975948
12/25/15 01:02 AM
12/25/15 01:02 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I've watched your video. If you have that much wobble at the wheel, it has to be almost 3 times that at the end of the axle in the center section. That's just nuts !!!
Re: Best alternative to a TruTrac [Re: crash520] #1975956
12/25/15 01:21 AM
12/25/15 01:21 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Stanton, granted there is some tire flex from me pulling and pushing, here is a vid of the side gear when I pulled the centre out. It has also started marking the spline of the axles about half way along the spline giving me cause for concern as for leading to a weakening of the axle, as for the noise, under load it makes no noise, on coast or through a parking lot, it sounds like a jam can full of oil with a half doz lug nuts being rolled along, and no amount of speaker volume hides it!!!!
[img]http://i3.photobucket.com/albums/y84/crash520/th_IMG_0137.mp4[/img]
Re: Best alternative to a TruTrac [Re: crash520] #1976110
12/25/15 02:14 PM
12/25/15 02:14 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
What do you have for axle bearings? Green non adjustable or tapered? If tapered do you have the spacer in the center between the axles?
Ron
Re: Best alternative to a TruTrac [Re: RJS] #1976245
12/25/15 05:38 PM
12/25/15 05:38 PM
USA
rftroy Offline
rftroy  Offline
USA
From the movement you have, I'm assuming you don't have conrad bearings (Green bearings), but have the stock tapered roller bearings.
I don't see the differential thrust block in your video. And, that side gear movement is normal. When under torque loads, the elements in the TruTrac 'find their own center' and the pinion gear loads keep the side gear centered.
Dr. Diff's site tells you that you need to install the thrust block when using stock adjustable bearings.
http://www.doctordiff.com/8-3-4-eaton-truetrac-differential.html
The thrust block should have been packed with your TruTrac. It looks like this:
Once you get the thrust block in, you'll be good to go. If you didn't get it, call Eaton. They have pretty good customer service, and they'll get you one.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Best alternative to a TruTrac [Re: crash520] #1976255
12/25/15 05:59 PM
12/25/15 05:59 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
After watching the video, I don't see that as a differential issue at all. I see wheel bearing issues. I'd defer to Cass here, though.
Re: Best alternative to a TruTrac [Re: crash520] #1976304
12/25/15 08:12 PM
12/25/15 08:12 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
using factory tapered bearings, yes the thrust block is installed, yes Cass is all over this and agree's there is a problem, the only way to reduce the 'rattle' is to tighten up the bearing end float to less than the 0.008" recomended however axle bearing failure is likely due to no end float, yes again under load it finds its centre as stated, it does not make a noise under load, the issue is on coast and around parking lots,,, its freaking loud. wheel bearings are brand new.
Re: Best alternative to a TruTrac [Re: crash520] #1976306
12/25/15 08:18 PM
12/25/15 08:18 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Hey, I know your problem.....change to a Dana 60 and be done with it. Less headache and you would be on the track already...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Best alternative to a TruTrac [Re: crash520] #1976316
12/25/15 08:48 PM
12/25/15 08:48 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks Tim, if they were more plentiful out here I would, shipping alone on a 60 would be close to the cost of one from Cass!!Then lets not talk about the exchange rate, the South Pacific Peso is not doing that great lately
Re: Best alternative to a TruTrac [Re: crash520] #1976327
12/25/15 09:22 PM
12/25/15 09:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I run a True Trac in my Imperial. Zero noise. That car is so quiet that I'd hear any noise the diff is making.
I hope they can get you straightened out.
- Stu Harmon
Re: Best alternative to a TruTrac [Re: crash520] #1976356
12/25/15 10:50 PM
12/25/15 10:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
mine is doing the same thing, I had green bearings at 1st, then the tapered,it is a problem with the side gears.
Re: Best alternative to a TruTrac [Re: crash520] #1976547
12/26/15 02:25 PM
12/26/15 02:25 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
My friend had a TruTrac in a 12 bolt. Love the differential action for cornering exits but also complained of noise. The driveshaft could be rotated 45 deg w the wheels locked.
He renamed it True Slack and returned to clutch style.
Re: Best alternative to a TruTrac [Re: crash520] #1976715
12/26/15 07:57 PM
12/26/15 07:57 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Yeah, I have to say I love the way it works through corners and burnouts, I love everything about it,,,,,,exept the damn noise, all they need to do is sort out the side gear float and they would be awesome. I dont want to go to a clutch, Ive had those before, a spool is just a PITA as is somewhat a locker on the street,
I JUST WANT A GOOD TRUTRAC Eaton sent me a warranty replacement but as indicated its equal to if not worse in side gear slop.
Re: Best alternative to a TruTrac [Re: crash520] #1976992
12/27/15 09:58 AM
12/27/15 09:58 AM
Minn
SportF Offline
SportF  Offline
Minn
There is two people above that call it a wheel bearing issue. Your wheel is flopping around and you think the center section should hold it in place? No, that is a wheel bearing issue, and you just can't have it set right if its tapered bearings. With the wheel flopping around like that, there actually would be very little movement in the center section, not an exaggerated movement. AND, there is nothing in the center section to hold the axle in, that is done at the wheel bearing. Good luck with this.
