RPM removale #1975618
12/24/15 12:59 PM
12/24/15 12:59 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Does anyone know how to remove RPM?
I applied it to my rotor dust shields before I learned they shouldve been painted. Id like real experience methods not a guess if possible.
TIA and MERRY CHRISTMAS Everyone!
Re: RPM removale [Re: LimeliteAero] #1975644
12/24/15 01:54 PM
12/24/15 01:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pure acetone
Re: RPM removale [Re: LimeliteAero] #1975695
12/24/15 03:20 PM
12/24/15 03:20 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I had a similar problem with another component and used Aircraft Paint remover in the aerosol can. I applied and removed the paint remover twice after letting it sit for about 20 minutes per time. I was able to prime and paint the part afterwards with no issues.
You’ll just need to be sure you fully remove the paint remover before you paint otherwise the paint won’t adhere.
Re: RPM removale [Re: B5Cuda440-6] #1975700
12/24/15 03:24 PM
12/24/15 03:24 PM
SE Pa.
SE Pa.
Thanks guys!!!
