Re: '70 Challenger door adjustment
[Re: Moparmaniacc]
#1975502
12/24/15 01:10 AM
12/24/15 01:10 AM
RapidRobert
does it appear that the door is parallel? I ain't a bodyman so I do not know if a hinge adj up front or a striker adj in the rear is in order (or a combo of both) but here's a BTT for ya
[Re: Moparmaniacc]
#1975774
12/24/15 05:49 PM
12/24/15 05:49 PM
Posts: 406 California City, CA
dart440
California City, CA
You need to adjust the hinges first. I take it that you are checking the gaps with the door closed, which if the striker is positioned properly, should be pretty good. If the door open is too low that it hits the sill plate, you need to get the door set level before adjusting the window gaps or you'll screw all of them up too.
When you work on Spaceships for a living, how bad can a workday be?
